Old 05-24-2004, 12:51 AM   #1
67pro-street
67pro-street's Avatar
anyone built their own lowering blocks?
i have a 4/4 suspension drop on my 67 and the back is just sitting too high for my taste, so i want to lower it some more. all i have right now is a 4" drop coil. i am taking shop class at high school right now and i am not doing anything, so i was wondering if any of you guys have built 2" lowering blocks. if so, can you give me instructions or pictures.
thanks,
67pro-street
67pro-street is offline   Reply With Quote
Old 05-24-2004, 01:05 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I used 4" C channel, cut two holes and welded 3/4' pipe where the U bolts go though then capped, basicly a box with two reinforced holes in it.
sneakysnake is offline   Reply With Quote
Old 05-24-2004, 09:01 AM   #3
1972ChevyGuy
1972ChevyGuy's Avatar
TX firefighter has some good pics of lowering blocks he done. Just take some good steel square tubing or some good angle and drill holes in it for the u-bolts. Get longer u-bolts and just bolt them in.
1972ChevyGuy is offline   Reply With Quote
Old 05-24-2004, 11:00 AM   #4
sactoC10
71 DELUX
sactoC10's Avatar
Yup, I made my own...but I use 1/2" aluminum bar, and made four for each side, so that I could play around with the 1/2" - 2" drop range out back. Came in handy as 2" was too much (along with my 3" springs), and I've currently decided that I like two plates. This is the way the DJM drop kit packaged and sold, but with 4 -1" blocks. If you go with 2", you will need longer U-bolts.
sactoC10 is offline   Reply With Quote
Old 05-24-2004, 11:27 AM   #5
Gee_Emm
I made a couple once out of solid stock, if you go that route you better have something good to cut it with :p
Gee_Emm is offline   Reply With Quote
Old 05-24-2004, 09:38 PM   #6
1972C10
1972C10's Avatar
I made some out of old trailing arms cut the ends off i still have them acutally i had a hard time finding 3 inch longer u bolts. but as i recall ed at mother truckers sells them i had bought springs since then so i didnt need blocks anymore. if you want to see pics let me know .
1972C10 is offline   Reply With Quote
Old 05-24-2004, 11:44 PM   #7
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
I have a set of lowering blocks that I would sell if you want them. Brand new never used or installed. I believe it comes with the U-bolts with the blocks. Haven't looked at em in so long I cant remember. But I think they did.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 05-25-2004, 08:23 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Ft Worth Champion spring on Henderson street will build U-bolts for you while you wait for 30 per pair.
Old 05-25-2004, 09:14 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
You cab build them, but why? They are so cheap to buy from PEP Boys that it's not really worth your time...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-25-2004, 09:42 AM   #10
Tx Firefighter
The Pep Boys one won't work on a coil spring 67-72 truck. They're for leaf spring applications.
Old 05-25-2004, 11:06 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Aaaah, that makes sense. I'm just used to leaf spring rear ends. I sometimes forget what forum I am responding in.... :p
Old 05-25-2004, 08:24 PM   #12
SweetandLong68
Your UncleBen
But the ones from Autozone will. A buddy of mine lowered the rear of his 68 CST with the same blocks that I have. I am going Bags and not going to use them.
I wrode in it after he cut the front springs one coil a put the blocks on the rear and it didnt ride bad at all. I was expecting much worse. All that spring travel that these trucks have I guess.
lata
CHRIS
Old 05-25-2004, 09:27 PM   #13
bad69
Struggling Artist
Blocks
I built mine out of 2" solid stock and drilled 13/16" holes on a lathe for the "U" bolts.g[/IMG]
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
Old 05-25-2004, 09:29 PM   #14
bad69
Struggling Artist
Darn pics didnt work
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
Old 05-25-2004, 09:29 PM   #15
bad69
Struggling Artist
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
Old 05-26-2004, 12:10 AM   #16
SweetandLong68
Your UncleBen
Those pics look pretty close to what we did bad 69.
lata
CHRIS
Old 05-26-2004, 12:16 AM   #17
67pro-street
thanks for the help fellas. i have one more question. how much longer should my new U bolts be. should i just take out the old ones, measure them, and then add two inches? I was thinking of taking 2" x2" steel tubing and then cutting two holes in it and reinforcing them with round tubing and then capping off the ends. Do you think that would be strong enough.
thanks, 67pro-street
Old 05-26-2004, 08:00 AM   #18
Tx Firefighter
Here's what I did. Just tubing that I capped the ends on.
My local parts store don't sell blocks that are even close to working. They are intended for leaf springs and come with 4 small diameter U bolts and the blocks have locating pins on them.
Old 05-26-2004, 02:15 PM   #19
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
So....I'm guessing you sit a jack under the trailing arm and lower it after you break loose the ubolts??? Or how do you do it???
Sorry to butt in.....but it is a question that needs to be asked.....just minor details I guess...
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 05-26-2004, 02:23 PM   #20
67gmcss
anyone have any pics of this with leaf spring trucks? Mine is leaf with the square spring "u-bolts" and i can't find crap that works at local parts places.
67gmcss is offline   Reply With Quote
Old 05-26-2004, 04:01 PM   #21
jays68yak
jays68yak's Avatar
I lucked out and found some of the square ones at kragen.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 05-26-2004, 09:01 PM   #22
bad69
Struggling Artist
Leaf spring blocks
Find someone that sells BellTech parts(summit racing)they have it all.
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
Old 05-26-2004, 09:10 PM   #23
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I built mine just as tx did and they worked pretty good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
