Garage Queen Material
dual fan wiring diagram?
i need the diagram to hookup a fan controller to dual fans.
i also need to know of a place to buy a 30a relay. would autozone sell them? |
BeWarE tHe eViL CrAnkTOe!
Eric....why dont you listen to me?? damn..Go to O Reillys. Get the 2 Hayden Fans, the Hayden electronic controller, Wire them as they tell you in the directions and be done with it! Under 170 bux for all of it! With a lifetime warranty. WOrks great and looks great. Very simple
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
i already have the two freakin hayden fans fool. they are already hooked up to a on/off toggle swtich.
i just lost the instructions so i needed them posted fool |
Retard...go to O reilly and ask for a copy of them, They can make you a copy of them with the Fax machine on copy mode. DUH! Friggin Tool!
BAD BOW-Silverado XST
Cat Fight!!!!!
Parts and more parts
Het it sounds to me that you already have a dual fan control. flip the switch and they come on, flip the switch again and they go off. Life is simple, isn't it?
i remember seeing a couple diagrams online to wire it up. i would really love to find those again.
i found the instructions with the hayden fans, but they dont detail it very well. |
oh yeah, how much coolant is gonna come out when i take a plug out of the head to install the temp. sensor?
That all depends on how fast you are!!
J/K It would be better if you just put a pail under the radiator and open the pet-cock and let it drain till it stops. That way you can control where all the antifreeze goes. Install the sensor/switch and refill the system. |
Eric:
Sent you an email with an attached wiring diagram (hand drawn) by a Product Technician with Painless Wiring. It is for a dual fan setup with a manual overide switch. Requires a total of 3 relays and a SPST switch. Diagram was too big to post. Good Luck!
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
I Have mine on Ign only via a bosch 30 amp relay I have thought about doing the thermal thing But on when the engine is on is fine by me.
#12 | |
#13 | |
![]() i'll have to rearange it cause i dont use the A/C though |
#14 | |
Yea but Im cheap and dont want to buy a thermostatic kit i have eyeballed the water pump kit in jegs the one where the sender screws in the head It would be ok.. It would be a cold day in hell when i put one of those cheesy ones that you stick in the rows of the radiator on my rig. I just like the convience of not having to remeber to turn the fans on so i have mine to where if the engine is running so are the fans. Cheap protection against Forgetfullness |
