06-28-2004, 04:15 AM | #1 |
LED King
Leaking fluids
My rear main seal has always leaked but not bad at all. Recently the truck has been leaving puddles. It looks like the oil dipstick tube is leaking. Does it have an O-ring or sleave to seal it?
My tranny cooling lines leak just a tad. How can I stop them from leaking? My rear differential has started leaking too. 3 leaks! Grrr!!! I guess it gives me me an excuse to change the rear cover to an aluminum or clear cover.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
06-28-2004, 07:00 AM | #2 |
yeller
Dipstick tube has an O-ring...a new O-ring and a small amount of silicone sealer should fix that. I would put a little bit of teflon tape on the tranny cooler line threads, that should stop that leak.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-28-2004, 09:30 AM | #3 |
Tranny cooler line is a flare. If it's leaking then it is either not tight enough or the flare is damaged. Becarefull about over tightening into the side of the tranny. It's aluminum and can be stripped.
I think there is an adaptor there and if so where the adaptor fits into the tranny the Teflon tape is the ticket like bigblock73 said.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
06-28-2004, 09:40 AM | #4 |
Tonawanda 454
since it is a flare fitting, teflon tape will ruin it and not let it seal properly, this is the case with all flare and compression fittings (i work at a hardware store i know these things )
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
06-29-2004, 01:22 AM | #5 |
LED King
So how can you fix the flare or the compression fitting?
06-29-2004, 06:55 AM | #6 | |
yeller
