V-8 In 6Cyl. Spot
Can I still use the same rod from colum to the pivot point or is there mods there to?I have everything slid back cause I didn't want to lengthen drve shaft.The combo is a 327/350.Do I need to move the pivot point back that is attached to the frame or keep it in the same spot?Any help would be appreciated.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
#2 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Everything is the same!! How do you get the pivot bracket and the u shape bracket to line up to the trans?
Watch out for your cornhole !
![]() Join Date: Jun 2003
You mean the pivot ball for the clutch linkage?
You need a V8 one, it just screws into a tapped hole on the engine block
Keep On Truckin'
Wear a kilt....Sheep can hear a zipper at 50ft
Tx Firefighter, I think I just ruptured my spleen laughing so hard at this
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
#6 | |
If you put the V8 in on the I6 mounts, you will see a tapped hole in the block that's even with the 6 cylinder z-bar mount on the frame. Take a V8 pivot ball and screw into that hole and you're good to go.
junkyardjohn Thanks for the info I appresiate it, I thought that is what needed to be done but it was a long frustrating day.
Txfirefighter I was refering to an auto tranny but allso appreciate the info for a manual setup again thanks to u both
