Old 07-16-2004, 12:12 AM   #1
imdarren
imdarren's Avatar
Door advice / opinions needed.
When I media blast and repaint the doors for my 72 resto, should I blast out the black goo / tar looking stuff on the inside of the outer door skin?
It's in fairly good shape. I'm just wondering what the purpose of that stuff is.
What would you guys do?
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 07-16-2004, 12:41 AM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Blast the goo???
I don't think you are going to have to worry about whether to blast that undercoating...blasting won't touch it. It is basically a sound deadener. If it is solid, you might leave it. So often water gets behind it and it rusts and falls off in chunks. It will take heat (carefully) and scraping to get it out. It is OK in there unless you ever have to weld where that stuff is located. Not a pretty sight.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 07-16-2004, 08:35 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I believe it also helps vibration. I wouldn't want to remove it myself. Without that, the door will probably sound cheap and hollow when shutting it.
I wish they would have coated the entire inside of my doors with it instead of just the middle. It's the only part that doesn't rust. I've never seen this stuff peel off on any that I had.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
