Old 07-20-2004, 02:08 PM   #1
UP GRADE
one set closer
UP GRADE's Avatar
6 inch drop
i'm going to drop my truck 6 inch in the rear with coils springs is there any thing that's need to be done like relocate the shock mounts or will it be fine just with the coils.what else need to done to do this right.thanks
UP GRADE is offline   Reply With Quote
Old 07-20-2004, 02:17 PM   #2
ed455
Captain Ed
I dropped mine four inches with coils and had to get an adjustable track bar and shock relocating kit.
ed455 is offline   Reply With Quote
Old 07-20-2004, 02:44 PM   #3
UP GRADE
one set closer
UP GRADE's Avatar
ttt
Old 07-20-2004, 05:00 PM   #4
Stroker
With a 6 inch drop you'll need to relocate the shock mount and install shocks for the lowered stance. You'll aslo need an adjustable panhard bar or kit of some type. You can get by without a frame notch but you'll probably need to shave down the rear bump stops to give the rear end a little extra travel. I've never used the progressive type aftermarket bump stops but they might be the best way to go if you have problems with bottoming out.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 07-20-2004, 05:42 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I run the whole ECE 6 inch rear kit with coils, super track bar shock relocators, and KYB shocks.
It is awesome. Hauls heavy loads without bottoming out, yet still rides real well.
Old 07-20-2004, 07:13 PM   #6
UP GRADE
one set closer
UP GRADE's Avatar
thanks alot guys i know what to do now.
