08-03-2004, 12:22 AM | #1 |
after market inner fender not fiting
I am puting on a used GM fender and an after market inner fender they are not lillining up right. Seams like it is not om the front
08-03-2004, 01:04 AM | #2 |
Taiwan stuff don't fit most of the time. Some adjustments may be neccessary. I like the Unibit, step-type drill bit for reaming mounting holes. Brian
08-03-2004, 02:16 AM | #3 |
Try this and see if it helps, go to the hardware store and buy the same dia. bolts and tpi (threads per inch) as the stock ones but longer (around 1 1/2'' or 2'' long) start at the middle bolt and just get it started (a couple turns) and then alternate the long ones from the hardware store and your stock ones. I've used this method before on different applications and it usually works great. Just make sure you replace the long bolts when the inner fender is close enough for the remaining stock bolts. Doug
08-03-2004, 05:20 PM | #4 |
You will need a punch or screwdriver to make it line up as well. I takes patience and leverage. It may be you wind up opening up a hole or two as well.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
