Old 08-13-2004, 11:09 PM   #1
MXracer
Check Timing ?
How do I set the timing on my 98 GMC 5.7 ? When I had the intake gaskets replaced they left the distrubutor loose. Thanks for the help
MXracer is offline   Reply With Quote
Old 08-14-2004, 07:28 AM   #2
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I just did that on my 95. there is some good info here,yours will be a little diff but you have to find the timing conector from the computer and disconnect it to set the timming.once you do that reconnect and clear the trouble code. Good Luck.BTW welcome to the board.
http://67-72chevytrucks.com/vboard/s....php3?t=114936
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 08-14-2004, 07:33 AM   #3
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Sorry,that info might be wrong,try this link and scroll down to 96-98 models
http://www1.autozone.com/servlet/UiB...9e.jsp#hd1-1-2
Is it Sunday yet???
68 Project
Old 08-14-2004, 08:01 AM   #4
MXracer
Thumbs up Thanks
Thanks for the help It appears I do not even need a timing light!! I don't know if my scanner will do what I need it to? I guess I will find out
THanks Again
