Help starting my 1988 GMC 1500
Hi everyone brand new to posting but a long time lurker! I have enjoyed reading and getting TONS of help from here. But now it is time that I post because I can't get this solved yet?
My 1988 GMC 1500 has been starting really hard lately. And today it just stopped starting. It turns over and cranks but I am not getting any spark. I have already replaced the ignition coil and still no spark. Could the distributor need to be replaced next? And just so you all know I have checked out all the fuses and recently had the fuel pump replaced. So any suggestions would be very much appreciated. Thanks!
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Check if you are getting spark at the coil, and at the distributor. Also while cranking probe the terminals on the coil with a test light, one of em should be pulsing if your getting a signal from the distributor to the coil.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com 6772chevycom@gmail.com |
Ok heres an update........
I had purchased a new coil and it was bad. Got another one and the truck started right up but than stalled after about 5 seconds running. Now it continually does this. Once I do get it running it runs fine for a while but then I was at a stop sign and pressed the gas and it drove about 20 feet and just stalled. I can't figure this out and am getting really frustrated. Any help will be very much appreciated!
| Bookmarks |
