fs: 1982 k30 parts in MICHIGAN
454 engine complete minus ps pump $750
4spd creeper trans w/ np205 tcase $350 (2) rustfree gas tanks with mounting brackets and switch $100 9' flatbed with headache rack and goosneck hookup $600 propane conversion kit (off of bbc) w/ tank $400 floorshift steering column $30
1957 Cameo Last edited by 72addict; 09-07-2004 at 02:18 AM. |
Anyone have rustfree sheetmetal for trade?
1957 Cameo |
how many miles on the 454??? what shape is it in overall??
might be "damn" interested in it email me at klambert@cebridge.net -bigarmzz- ![]() |
#4 | |
91 suburban/blazer front clip, 81-91 longbox and maybe 81-87 cab and doors. That sounds like one truck, but I am working on a couple trucks. Anywhere close to what you have?
1957 Cameo |
Sorry. I have a 79 clip and cab available. I "built" a 91 front clip, but that is going on my 79 c-10.
I do have 2 door shells, but they need minor repair on the bottoms. What condition is your column in? is it tilt? |
column is tight, not tilt.
1957 Cameo |
k30 parts
DUALLY REAR????????????????????? does it have one and what ratio and price.
Actually I have a 1977 c30 cab and chassis from Wyoming that has no bed. It has a 4speed tranny (was a bbc truck) and six 16" dually wheels and a 14 bolt rear. I will take $600 for the whole truck. Interior is shot. there is rust in the bottom of the front fenders.
1957 Cameo |
Oh,you can't buy that new
![]() Join Date: Apr 2000
let me know a measurement on the driveshaft from center of U joint to center of Ujoint. one piece or two piece? if available a pic would help. thanx , DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
I will be using the rear shaft. I do have others though. What length do you need?
1957 Cameo |
roughly 68" from center of U joint to center of Ujoint. one piece that is and of course it will have the slip joint built in so the measurement is not an exact one. thanx , DAVE
#13 |
nothing that long. I don't think you can even buy a tube to build one that long.
1957 Cameo |
#14 |
well the tube itself won't be that long,much shorter, because it's like two separate pieces that the slip-spline is near the front end of it. both ends of mine bolt on the same as the rear normally does. just out of curiousity what does the one out of the 82 measure? DAVE
#15 |
![]() Join Date: Feb 2003
454
What are the numbers on the heads & block ? I have '68-'72 sheetmetal.............Zoomy
