Old 10-17-2004, 07:39 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
whats the diff between 71 and 72 doors
This may sound like a stupid question but whats the difference between 71 and 72 chevy and/or gmc doors, and also can 72 door panels be used on 71 doors?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 10-17-2004, 07:56 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
67 - 71 doors have short windoe regulator shafts...the shaft that the window crank goes on.
In 72, they had long shaft regulators, and a small screw under the wing vent to help battle the doors splitting. There may be a few minor differences due to the plastic panel, but that could probably be solved with a drill.
The panels couls be swapped with the addition of the window regulator and the posability of drilling a hole or two.
Old 10-17-2004, 08:04 PM   #3
Blue85
Oilfield Trash
Blue85's Avatar
koo thanks alot
87 Chev 3+3 4x4
Old 10-17-2004, 08:35 PM   #4
Solver
Solver's Avatar
I would love to hear from someone who has addressed this problem .
I have swapped 72 panels on to pre-72 doors and it was a pain.
71 and older have captured nuts built into the door for the panel screws and 72 have holes for plastic door panel retainers.
The captured nut holes are to small for the platic push clips of the 72"s and don't line up exactly.
If you knock out the captured nuts and just use the hole left there the holes are way to big for the push in plastic clips. As I said I have tried and accomplished this but was not satisfied with the fitment of the panels.
Who has done this and what was your process?
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 10-17-2004, 09:03 PM   #5
lamar
lamar's Avatar
I did it on mine and used I think they are called barrel nuts. Got them at the hardware store. They are just a long rubber groment type thing with a nut inside so when you tighten it, it draw the rubber in tight. Kinda the same idea as the tie down hooks that go in the bed post holes.
lamar is offline   Reply With Quote
