70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Buckets And Console
I posted this on the parts page and it was suggested I should post this here on the message board instead. I picked up a set of buckets with the console from a 96 Chev Silverado Ext Cab. I am going to install them in my 72 Chev but also have an Early Classic Enterprises rear frame mounted gas tank to put on the truck too. Has anyone mounted a set of these seats in a 67/72. If so was the gas tank still in the cab? If the gas tank was out of the cab could you mount the seats further back or do the seats mount the same if the tank is in or out? I have long legs and want as much leg room as I can get.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Got Light Emitting Diode?
you dont gain much room with the tank out(unless you like sitting at 90*), since it is the same angle as the seat and the top of the seat hits the back of the cab first.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
That is what I was looking to find out. What you are saying makes sense to me.
