It followed me home?
How do I remove ignition switch?
I lost the key to my '73
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
well you pop off the wheel get that tool to compress the piece under it and out the ring clip under it pop that out then there should be a screw or some clips that hold it in under the turn signal switch its pretty easy. for $25 why not just buy another ignition switch new and have TWO ORIGINAL KEYS
so many trucks so little time!!! |
#3 | |
Insert Witty Text Here
Slonaker |
White 82
if it is the factory ignition all u need is the vin no then go to the delearship and they can cut u another key i done this several times
the locksmith should be able to do this 2 but he probley didnt tell u that
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6 |
#5 | |
I will try that, they problem is I need a key by monday and none of the parts stores in town can get the parts I need til then, thanks. Adam
White 82
on my 69 gto they couldnt do it by the vin but i pulled the passanger door lock it had 4 digit no on it he looked it up on his pc through detrot and found a pattern cut for it i still got the keys he cut it works good
Used to do locksmith work on the side.
Always amazed me at what they charged, even just to come out.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#8 | |
I'm back with 2nd truck!
If you want to change out the cylinder here's the info. Also a god time to tighten up the bolts that the guy ends up doing in this article. http://home.t-online.de/home/O_Scholz/steering.html
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
