Old 12-18-2004, 11:12 AM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Question Brake Rotor R&R Question
Do the rotors just slip off over the lug studs, or are they pressed on to the hub? I've seen illustrations of rotors and of complete rotor/hub assemblies, and I'd like to get the right parts before I start the job. And are the cheap ($25) rotors any good? Truck is driven daily but mostly short trips in town, hasn't had heavy hauling or much highway use for years. Thanks, guys.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-18-2004, 11:40 AM   #2
Zeke
Active Member
I might be wrong but I think they are one piece rotor and hub assembly. From what I saw the $25 one only have a 3 mo warranty and $34 have 2yr (autozone)
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 12-18-2004, 11:54 AM   #3
68LSS1
68LSS1's Avatar
Parts store rotors are fine. It will probably come with new bearing races so now would be a good time to replace the bearings. I can't see why Autozone would have two different rotors. I don't see what they could have different to have a year longer warranty on one. Don't forget the hi-temp grease for the bearings and seal.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-18-2004, 12:11 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Talking
Just My $.02, I Used To Work Part Time In A Muffler & Brake Shop,
We Had 2 Turn, Yes Turn, Autozone Rotors New Out Of The Box 3
Out Of 5 Jobs We Ordered Them From, Advance Auto Was Better,
We Only Did It About 1 Out Of 5, Napa And Mighty Were The Best,
But They Also Were Higher, Mighty Is The Highest Because They
Sell Premium Parts To Shops Only, Not To The Individual Person.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-18-2004, 01:20 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When I Googled "Kragen" (there's one an hour away), this is what I got http://www.partsamerica.com/SelectPa...r=Disc%2FRotor and they show 8 rotors, though 2 are repeats.... thus my confusion...
- Mike -
RIP El Jay
Old 12-19-2004, 03:25 AM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The studs hold the rotor to the hub. You can either use a press to R&R them, or if you're careful you can do it with a hammer and old extension...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-19-2004, 12:40 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Chuck
Yup - that's exactly what I discovered late yesterday after taking one off. Parts store said they had 'em, so over the mountain I went, but they were for C20, not K20 . So, with no way to press the studs or turn the rotors, I got a cheap set of pads to put things back together for now. Rotors are grooved a bit but they'll work for my slow around-town driving. Thanks for the input, guys.
- Mike -
RIP El Jay
