Old 12-23-2004, 10:28 AM   #1
arkracing
Weekend Warrior
trailing arms????????
anyone ever welded thier trailing arms back together. I have one that is seperating..it only looks like they are spot welded together...
has anyone ever drilled out the spot welds and re welded them and then put a couple of stiches in the seams?
the arms aren't pitted or anything and the dr's side is nice..it's just the pass side is seperating for some reason (well water gets in them..i know that, but i don't know why it is just one side)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 12-23-2004, 11:06 AM   #2
FirstGen
Just Don't Stop!
FirstGen's Avatar
weld it up!!! definatly not going to hurt anything!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 12-23-2004, 02:55 PM   #3
jay-dawg
chevelito
jay-dawg's Avatar
I think ECE has a weld on plate that goes over the top of it.
Jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 12-23-2004, 04:16 PM   #4
72CSTC5
72CSTC5's Avatar
Mine were not coming apart but I did run 4 stitches on each side of the contorl arm about 1.5 inches each to reinforce them some. It won't hurt, just make sure the ubolts line up in the holes and the front holes line up before you reweld them.
72CSTC5 is offline   Reply With Quote
Old 12-23-2004, 04:33 PM   #5
arkracing
Weekend Warrior
thanks guys. i think i'm going to drill out the remaining spot weld them bolt the two sides together then stich the top and bottom then go back and take the bolts out and weld up the holes.
i figured that it would be ok...the factory did it without stiching the tops and they put bigblocks against them.
-'66 C10 Suburban
