Old 02-01-2005, 01:50 AM   #1
NorthWolf33
Axle Experts....quick question
I was readin through the other posts and got confused on axels and numbers and stuff soooo.....
does anyone know off the top of their head the axle ratio for a 90 Blazer...700r4 trans w/350 small block? and what a good axle combo would be for it if I plan on muddin every now and then, but mostly a daily driver for now? its a beefed up 350 too so its got some rpetty good horse.
NorthWolf33 is offline   Reply With Quote
Old 02-01-2005, 02:03 AM   #2
GenIIIShorty
JUNK COLLECTOR!!!!!
GenIIIShorty's Avatar
if it's a stock, untouched axle, it should have a tag on it somewhere, telling the ratio...also, prime axle ratio depends on tire size
baby
The dark side! 2000 XLT PSD F-250 4x4! Offroad package
1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3
GenIIIShorty is offline   Reply With Quote
Old 02-02-2005, 12:37 AM   #3
Americanrider
Check the glove box door tag and write down any codes that start with the letter "G" then call the chevy parts counter guy at your local dealer, I know my code on a 91 PU was GUU, it was in the high 2's .... It's been a while & I sold that truck a few years back.
Americanrider is offline   Reply With Quote
Old 02-02-2005, 10:49 PM   #4
alf4444
alf4444's Avatar
We could help with a suggestion for gear ratio if we had more info like tire size
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 02-03-2005, 12:16 AM   #5
kwmech
About a 90 percent chance of being 3.73s
Old 02-03-2005, 01:09 AM   #6
u2slow
Web Wheeler
u2slow's Avatar
3.42 or 3.08 are very common in these last few years of the K5 Blazer/Jimmy.
The 'G' codes from the glovebox indicate a ratio. Post the codes here for decipering our you can probably Google them up yourself.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 02-03-2005, 02:15 AM   #7
NorthWolf33
oh sorry tire size right now are 33's on a 4in lift
Old 02-03-2005, 10:15 AM   #8
alf4444
alf4444's Avatar
i think 3.73 would be fine thats what I'm running on my 97 with 33"s
73 GMC 3/4 ton 4x4
Old 02-03-2005, 11:12 AM   #9
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
I have 33" on my 78 and it has 4.10's in it. It gets down pretty good when you got it in the mud...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 02-04-2005, 05:39 PM   #10
sleekster
if your running a 700r4 and 33" tires go with a 4.56 i had the same combo in my suburban 350/700r4/33"tires/4.56 ran like a raped ape, plus at 60mph you are only running 1950 rpm and at 75 2437rpm, you will probably get better gas mileage around town due to the mechanical advantage your gear will give you. also if you ever want to step-up to 35 or even 36 tires you will still have enough gear which is what i did.
sleekster is offline   Reply With Quote
