Old 02-23-2005, 02:09 AM   #1
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
305 H.o.????
has anyone ever heard of a 305 high output cause my buddy has a friend that had an 82 camaro it had a 305 that had 5.0 (which my truck has thats why im asking) cause every other 305 ive seen is a 5.3
any input would be great?!?!?
cb
heres sum pics of my truck
82 silverado c10
heres my baby
1990 k1500
check out this 1957 chevrolet for sale
CbHeEaVsYt is offline   Reply With Quote
Old 02-23-2005, 02:31 AM   #2
Destructo
305ci motors are 5.0L, and some camaros came with 5.0L high output motors, which is just a 305 with a little more power.
the new 325ci motors and the older 327s come out to 5.3L.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 02-23-2005, 10:22 AM   #3
TrainD5115
North Coast, baby!
TrainD5115's Avatar
The high output package on an 86 Z-28 had a dual snorkle air cleaner if memory serves. I haven't heard of one in a 73-87 yet but I am wrong frequently.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 02-23-2005, 10:42 AM   #4
stepside454
stepside454's Avatar
Yep..what destructo said...305 is a 5.0... the H.O. part didnt mean a whole lot more than marketing really. some people claim the H.O. had better heads, but the heads on any of the 305 H.O.s Ive ever pulled apart are the same casting # as any other early 80s 305 4 barrel Ive pulled apart
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 02-23-2005, 10:44 AM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
The H.O.'s did have more compression than normal 305s and a hair bigger cam.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-23-2005, 10:57 AM   #6
MylilBowTie
Right turn Clyde
L69 1985-88
Type: 90-deg. V-8 Front Longitudinal
Displacement: 305 cubic inches (5.0L)
Horsepower: 180@4800 RPM
Torque: 225@@3200 RPM
Max RPM: 5500
Idle RPM: 650
Compression ratio: 9.5:1
Block: Cast Alloy Iron
Deck Height: 9.025"
Deck Clearance: 0.25" below
Bore: 3.740"
Stroke: 3.480"
Bore Spacing: 4.400"
Crankshaft: Nodular Cast Iron
Pistons: Cast Aluminum Alloy, flat top
Rods: 1037 or 1038 Cast Steel
Camshaft: Hydraulic flat tappet
Cam lift: .404"/.415"
Cam duration @.050: 202/206-deg.
Advertised duration: 320/320-deg.
Lobe Seperation: 115-deg.
Heads: Cast Alloy Iron, 58cc
Valve size: 1.84"/1.5"
Intake: Cast Aluminum Alloy
Carburetor: 795cfm Quadrajet four barrel
Old 02-24-2005, 12:38 AM   #7
Lynx
Lynx's Avatar
what kind of numbers does a Normal truck 305 put out?
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 02-24-2005, 01:38 AM   #8
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
has anyone ever heard of these in our truck cause my truck has to much power to be stock cause i drove my friends which had less miles than mine and mine has way more power
j/w
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-24-2005, 06:30 AM   #9
MylilBowTie
Right turn Clyde
For the 1984 Sales brochure I have. There are two 305's LF9 (California emission spec) and LF3 (non emissions California spec)
Type: V8 OHV
Displacement: 5.0 (305 Cu. In.)
Bore and stroke 3.74 x 3.48
SAE Net Horsepower: LE9 160 @ 2000 rpm LF3 155 @ 4000 rpm
SAE Net Torque: LE9 235 @ 2000 rpm LF3 245 @ 1600 rpm
Compression Ratio: LE9 9.2:1 LF3 8.6:1
Old 02-24-2005, 04:34 PM   #10
stepside454
Cb could have alot to do with gearing, if your truck is 3.73 gear & his is 2.90, yours is going to feel more powerful taking off & around town
Old 02-24-2005, 05:57 PM   #11
MylilBowTie
Right turn Clyde
Not to pick on civics but they have really low gears and still don't feel any of the torque. I could tell a decent difference going from a rear that had 2.73s to 3.08s.
Old 02-24-2005, 07:31 PM   #12
Low84
Low84's Avatar
Type: V8 OHV
Do you have any specs on an 84 350?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 02-24-2005, 08:25 PM   #13
Boog
laying low
Boog's Avatar
I looked at an 86 Blazer with 305. The guy said it was the HO and the same engine put in the monte SS that year. Special ordered he said. I didn't buy it.
Boog
Old 02-24-2005, 11:58 PM   #14
edman87
junk collector
Never heard of a 305HO, your buddy might be referring to the crossfire 305, which had 2 tbi uints on them, I know these were available in some early to mid 80's camaros, vettes, and montes
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 02-25-2005, 12:00 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
They did put the 305 HO in the Monte SS. They DID NOT put it in any truck....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-25-2005, 01:45 AM   #16
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
can neone tell me how to identify my drive train so i can figure out y is so darn quick for a little 305????
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-25-2005, 05:07 AM   #17
MylilBowTie
Right turn Clyde
With out looking and decoding what you have you could have. It could be any of the sbc family, 327 - 350 - 283 - 265 - 305 - 400 or whatever someone put in there so it could have a 305 HO but is unlikely that it is.
http://www.Mortec.com can be a pretty good friend. There is a casting number on the driver side head next to the firewall where the engine and transmission bolt up at. That will tell you what you have. If its newer it will have 5.0 SGI or 5.7 SGI. If you have trouble finding it http://www.mortec.com/location.htm and the casting numbers page http://www.mortec.com/castnum.htm
I use the last 3 numbers and goto the tool bar and use the find option with the last 3 digits to the engine code like 010 for a 3970010 (350) makes it easier and you don't have to look down that whole list or miss it.
Transmission will depends on the shape of the pan, number of bolts, if it has a modulator valve and where its located.
Any pictures of anything you cant figure out will help a lot also.
Type: V8 OHV LS9: light duty emissions LT9 Heavy duty emissions
Displacement: 5.7 (350 Cu. In.)
Bore and stroke 4.00 x 3.48
SAE Net Horsepower: LS9 165 @ 3800 rpm LT9: 160 @ 3800 rpm
SAE Net Torque: LS9 275 @ 1600 rpm LT9 250 @ 2800 rpm
Compression Ratio: LS9 8.2:1 LT9 8.3:1
Also for California spec 350 was the LT9 but is rated at 155 horsepower @ 4000 rpm and 240 torque @ 2800 rpm
Old 02-25-2005, 05:11 AM   #18
MylilBowTie
Right turn Clyde
Your Differential (rear end) is most likely a 10 bolt 8.5 (28 spline axles), you can also decode those with the help of some other members. But it doesn't really help much if the gears have been changed out for a different ratio.
Old 02-25-2005, 01:00 PM   #19
84 PUMPKIN
H.o. 305?
I have a couple of very interesting photos related to this subject if someone could post them for me.
84 PUMPKIN is offline   Reply With Quote
Old 02-26-2005, 02:07 AM   #20
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
ok i know this it has OD which means th700r4 it appears to be stock motor but u never know i cant get to the casting numbers right away cause i have it in storage right now but got a chance to drive a day before i qeustioned the motor it says 5.0 305 on the radiator support stock sticker it is a silverado 82. i think it may have been a california truck cause jve never EVER seen that many vacuum lines and before i changed out the stock exaught for duals it had two catylac converters and 2 mufflers its got all the original smog pump and emmisions so unless some just ripped it out of a cali car whole then again u never know ive seen stupider stuff done well that is wat i can remember off the top of my head please tell me if i helped u ne my lil bowtie
and i can post those for u 84 pumpkin
or anyone in here have intrafan just download that at intrafan.com and u can resize them
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-26-2005, 03:19 AM   #21
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
ok made a mistake the program is IrfanView
www.irfanview.com
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-26-2005, 03:24 AM   #22
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
here is a direct link http://quantum.tucows.com/adnload/194967_75076.html
cb
82 silverado c10
heres my baby
1990 k1500
Old 02-26-2005, 11:03 AM   #23
MylilBowTie
Right turn Clyde
Here are the pictures I was sent from 84 Pumpkin.
What would I would like to see is the paper work on the truck. I've seen the pictures so far, wouldn't mind seeing some more if they are available. I'm still not decided about it just yet.
Old 02-26-2005, 11:12 AM   #24
chevyjr73
chevyjr73's Avatar
does anyone know where i could buy one of those dual snorkel air cleaners?
chevyjr73 is offline   Reply With Quote
Old 02-26-2005, 11:22 AM   #25
MylilBowTie
Right turn Clyde
Im pretty sure gm doesnt make them anymore, might try to find a 83-85 Camaro or Monte Carlo to get one.
