Old 03-20-2005, 11:43 AM   #1
chevybill
chevybill's Avatar
Question Opening up the steering box?
I am completing a frame off resto/mod on my 70 c 10 lwb.
As far as I can tell my steering box is in good shape. I want to replace all the grease inside the box. Should I just remove the 3 bolts on top of the box? Are there any spring loaded parts that will "jump" out if I remove this top section? Does anyone have a good procedure for replacing the grease in the steering box, it is a manual steering box.
Thanks for all your replies.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 03-20-2005, 08:26 PM   #2
chevybill
chevybill's Avatar
ttt
Old 03-20-2005, 08:40 PM   #3
JimKshortstep4x4
Talking
Unless you completely dissassemble th box, getting the grease out will be almost impossible. Removing the cap is ok to do, no springs!
I would suggest removing two of the four cover bolts, (one diagonally from the other). Using a grease gun with a tapered rubber tip, purge the box by pumping into one hole and letting the grease come out the other hole.
Jim
Old 03-21-2005, 09:45 AM   #4
chevybill
chevybill's Avatar
Thanks for the idea Jim.
Any other thoughts or advice? From anybody?
Old 03-21-2005, 10:35 PM   #5
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
As Jim said, the only way to get all the old grease out is to completely disassemble the box, scrub everything clean, and reassemble it.
Just watch those ball bearings. There are 50 of 'em & they love to roll across the floor to hide in inaccessible places. (Voice of experience here)
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 03-21-2005, 10:55 PM   #6
mr402
Think of opening a box of little compressed springs. OK, maybe not quite that bad. Last time I did this I took it apart in a large bucket just to make certain I didn't lose any.
mr402 is offline   Reply With Quote
