73-74 grille in a 77 - ???
What do I need to change to install a 73-74 grille in my 77? I was thinking that the center grille support had to be changed. Does anyone know?
![]() Join Date: Mar 2005
The 73-74 core support is different than the 75 and up. The grille attach brackets are welded to the core support, whereas the 75 and up versions have bolt-on brackets. I doubt that the 77 core support will hold a 73-74 grille because the early grilles are deeper, and the later brackets would stick the grille out too far.
________ New mexico marijuana dispensary Last edited by chevyrestoguy; 02-18-2011 at 10:50 AM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
The core support will work, but the header latch panel, center brace, latch mechanism, and grille support items are specific to the 73/74.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Thanks for the help
