Old 06-10-2005, 10:40 AM   #1
bwright
Q-Jet Problems
Just started yesterday. Symptoms: won't start, leaking fuel onto the intake manifold.
Even and temporary fix would help (I'm going to pull the motor anyhow), just to get the thing into the garage.
bwright is offline   Reply With Quote
Old 06-10-2005, 11:31 AM   #2
Brad_Olson
Active Member
Brad_Olson's Avatar
Any idea where on the carb the leak is?
Brad
Brad_Olson is offline   Reply With Quote
Old 06-10-2005, 11:49 AM   #3
bwright
It appears to be coming out the top...hard to tell for sure though. I got it running (barely) but it died just as I was pulling in the garage and it wouldn't start (flooded).
Old 06-10-2005, 12:49 PM   #4
Brad_Olson
Active Member
Brad_Olson's Avatar
Could be a bad float or some debris is preventing the inlet needle from seating. Sounds like it might be time for a new float at the very least...
Brad
Old 06-10-2005, 06:37 PM   #5
jermasaurus
jermasaurus's Avatar
If it is coming out the vent, it is may be a saturated float or debris like Brandon said.
I don't know if it's a daily driver or what but if you have the time, pull that thing off and check it out. I was kind of intimidated by all the parts in the quadrajet, but if you read a manual as you go you can really get an understanding of whats going on.
jermasaurus is offline   Reply With Quote
Old 06-13-2005, 12:58 AM   #6
jimfulco
Try tapping the carb inlet area with the plastic handle of a big screwdriver. Sometimes it will dislodge the offending float & get it working normally again.
jimfulco is offline   Reply With Quote
Old 06-13-2005, 08:33 AM   #7
bwright
Thank everyone for the help. I ended up getting it to run (barely) long enough to get it in the garage (where I'm tearing it down for resto anyhow).
