Old 08-27-2005, 10:25 PM   #1
aquik72gmc350
How to Remove Upper/Lower Control Arm Shaft?
Just like the title. How do you remove the upper control arm shaft? First you remove the nut on each end. Then does the retainer and bushing slide out or does it unscrew out? I have the same question about the lower control arm shaft. Thank-you for the help!
aquik72gmc350 is offline   Reply With Quote
