Old 07-01-2002, 12:14 AM   #1
RipMeyer
RipMeyer's Avatar
Question Who Is Running A 350 RAMJET?
Do you have one or have you experienced one?
Likes, dislikes? Worth the money? How did the install go?
RipMeyer is offline   Reply With Quote
Old 07-16-2002, 08:49 PM   #2
pro_ject
My buddy put one in his 89 shortbox chevy a year ago, he ran into little problems nothing to big tho, power wise it goes pretty good, smokes those **** "ford lightings" all the time, money wise its hard to say, might be better to build one but if yer looking for sumthign to just put it that gets alright mPg id say its worth it
pro_ject is offline   Reply With Quote
Old 07-17-2002, 12:32 AM   #3
lofly'a
lofly'a's Avatar
i don't know if it's worth it, but i dam sure want one. if you're gonna run a fuelie and must start from scratch, i think it is cost effective see'in that a efi system alone runs about 2500.00 and the entire pkg. runs about 4k. oh yea, i want one. now if i can just convince the wife that i need one.!?!?!?!??????:p
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 07-17-2002, 02:46 AM   #4
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
I dunno.. if I was gonna drop the money on an EFI engine, I think I'd go all the way and get the 502 Ramjet.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 07-19-2002, 03:28 PM   #5
Charlie Coleman
Charlie Coleman's Avatar
I put one in my 68 4x4. There are a few issues to resolve as you go along, but well worth it. I was going to build a motor and add the fuel injection, but for about the same $$$, I bought the RamJet. I bought mine two years ago, so I battled a few issues that now is offered as an after market part. Go for it!
Charlie Coleman is offline   Reply With Quote
Old 07-19-2002, 04:10 PM   #6
SCOTI
SCOTI's Avatar
Charlie, what were those issues? Does the block have a provision for the necessary ballstud required for a clutch z-bar? Thanks for any info.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-19-2002, 04:49 PM   #7
Charlie Coleman
I can't answer about the bolt hole for the clutch z-bar. I will say that I have found a hole for everything I wanted to bolt on. I am running an automatic. As for other issues, it's been mostly conversion type problems. Fuel tank with a sending unit for a larger return vs fuel source, pulley system, fuel system fittings, etc. The literature that comes with the motor is not real clear either. It left me scratching my head more than once. Of course if I did this again, it would seem way to simple. GM now has answer for some of these questions. They sell a complete serpentine pulley system, air cleaner, fuel fittings, etc. It really should be as simple as connecting a few wires, and firing the bad boy up, if only the directions were clear. I should write a book on this now! Hope this helps, and feel free to ask any questions if you choose to install one of these motors.
I did find Burt Chevrolet (Denver) and Scoggin Dickeys to be helpful with some of my questions.
Old 07-19-2002, 09:09 PM   #8
Cheyenne Super
why not an lt-1
i found a place that has lt-1s with 4l60e tranny computer and harness from 1450-2150. that's what i'll do.
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
Old 04-23-2012, 09:29 PM   #9
x ReAcT x
Re: Who Is Running A 350 RAMJET?
Im buying the RAMJET 350 CRATE in a couple days and will be putting it in a 86 GMC 4x4. What are some of the best peices of advice you can offer me regarding what you have learned. Just some facts about the truck:
- currently a 4 spd manual but hopefully ill be able to upgrade to a 5 speed if thats possible to mount up to this type of engine.
- currrently have a 3.4 v6 in the truck
- do i need an electronic fan for the new engine?
- what kind of fuel pump do i need, can i use the stock fuel pump i have? im assuming no
- does the engine just drop right in or did you have to modify the frame or engine mounts?
- GM recommends 92 octane gasoline, is that a requirement or can i use 87 regular?
- Does have a good tune stock? i plan to put a true dual exhaust on it.
- Hows the mpg?
x ReAcT x is offline   Reply With Quote
Old 04-23-2012, 09:31 PM   #10
Pro Performance
Pro Performance's Avatar
I believe Ken (N2Trux) has one in his C10. I am sure he can give you some good feedback.
Pro Performance is offline   Reply With Quote
Old 04-24-2012, 01:45 AM   #11
FirstOwner69
FirstOwner69's Avatar
I don't have the ram-jet 350 from GM Performance Parts, but I did get a 350/330 HP Deluxe. I have yet to start it.
The best advise I can give regarding the multitude of questions you'll have is to call the GMPP tech line. They have extremely knowledgeable and helpful employees. The first thing they'll do is assign a case number so on future calls all you have to do is give them your case number, and they have all your information at their fingertips. I asked most of the questions that are asked in the above posts during my first call and got GM part numbers for the things I'd need, advise on installation and suggestions on the things GM couldn't supply such as a kickdown switch for my TH400. I've probably called 5 times and they are still very patient with my dumb questions! I feel it has been the best customer service I've ever received for ANYTHING I've ever purchased.
Here's a link to the GMPP installation guide that will be with the engine and will also provide some answers.
http://www.gmperformanceparts.com/_r...Jet_Engine.pdf
Jim
Last edited by FirstOwner69; 04-24-2012 at 02:14 AM. Reason: Added link to installation guide.
FirstOwner69 is offline   Reply With Quote
Old 05-10-2012, 09:45 PM   #12
x ReAcT x
Jim
Would you mind giving out the GMPP tech line? Ive been searching all over google and i havent had any luck in finding it. Thank You for the info -Jerry
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
Old 05-10-2012, 11:11 PM   #13
FirstOwner69
The number is for the "Power Train and Performance Parts Contact Center". They will ask you to select Chrysler, Ford or General Motors. I don't recall where I got the number, but it was before I bought the engine so it had to be either the GMPP catalog or their website. The toll free number is: 866-637-2787.
There are also numerous helpful FAQs on the GMPP website (www.gmperformanceparts.com).
Jim
Old 05-12-2012, 11:53 PM   #14
x ReAcT x
Jim
Thank you, I really appreciate the help
Old 05-13-2012, 12:33 PM   #15
Spoof
Spoof's Avatar
I have 1200 miles on the Ramjet dropped into my 71. I had a mechanic drop it in, just a young kid and he had absolutely no problems. The HEI and stock tach don't work together (sometimes happens ramjet or no)
The power is satisfactory, the sound is perfect, the look is sweet.
Driveability is fantastic!
Turn it over till the fuel pump primes, it starts before the engines halfway turned over. I can then drop it into gear and back it out of the garage the second after it starts, no warm up. It runs like an absolute dream, I will never go back to a carb engine.
Plug it in and read all the info on your laptop, even buy tuning software to change the program (you can't tune a ramjet otherwise) I haven't gotten around to installing my software yet since I have a Mac ( not as happy with that decision) but I've really had no need to except for curiosity.
I've have no problems with the MEFI 4 at all.
There are a lot of sensors which require some artistry to sort away in the engine bay and still look good. Street and performance has tons of dress up gear for the Ramjet if you feel like you still haven't spent enough money.
I'll try and post some pics later.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 05-13-2012, 11:12 PM   #16
Spoof
Spoof's Avatar
Pics as promised. Drove her all day today...like a boss.
71 GMC 1500 LWB
Old 05-14-2012, 01:39 AM   #17
x ReAcT x
Wow I only wish I could have a truck that looked that good, you did an amazing job. Im glad to hear the motor is working good, Ill be ordering mine soon. What type of exhaust manifolds did you use?
Old 05-14-2012, 09:40 AM   #18
Spoof
Spoof's Avatar
Sandersons, purchased from Early Classic Enterprises.
71 GMC 1500 LWB
Old 05-14-2012, 10:57 PM   #19
x ReAcT x
Would you recommend those is there a different brand that might be better? The only thing im really concerned about is the manifolds hitting the frame, because Im strongly against cutting the frame.
Old 05-15-2012, 10:24 AM   #20
Spoof
Spoof's Avatar
I've never heard of anyone having trouble with the Sandersons which ECE sells for 71's but I can't speak for your model. Plenty of room on mine though. They are a highly regarded header manufacturer, price is on the high side.
71 GMC 1500 LWB
Old 05-15-2012, 03:09 PM   #21
x ReAcT x
Thank you i appreciate it.
Old 05-18-2012, 12:51 AM   #22
RAT-AT-TACH
RAT-AT-TACH's Avatar
sweet lookin truck.......for an old timer!!!!
i cant believe i came across this site again and rememberd my username and password lmao its been 7yrs
who says moneys not everything....try running a rat!
RAT-AT-TACH is offline   Reply With Quote
Old 06-12-2012, 11:33 PM   #23
x ReAcT x
What kind of fuel pump setup did you use for your swap? I have an 86 so mine will be a bit different but do you know if there is an electronic fuel pump that is a direct fit into the stock fuel tanks for these trucks or did you have to go the external fuel pump route. This is my first time doing this so im just looking for the easiest option. Any help would be much appreciated. Thanks, Jerry.
