09-05-2005, 07:00 PM | #1 |
68 in progress
68 with 74 c member brake line ?
I have a 68 pickup with a cross member off of a 74 and I dont know what brake lines to order. Should I order the lines for a 74 front end and front to rear lines for a 68 or what. I know someone has ran into this problem with all the crossmember swaps folks are doing.
09-05-2005, 08:40 PM | #2 |
I am using the lines form a 73 with my 73-87 spindles. The hole is in the frame for them to run into. Go with the 73 up they should work out for you. They did for me.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
09-05-2005, 09:27 PM | #3 |
I also used the 73-up style lines when I swapped to discs on my 68. I . . ....
I did need to space the prop-valve about a 1/4" away from the splash apron for a better fit on the lines as they entered the valve (I used over-sized nuts as spacers).
09-06-2005, 09:16 AM | #4 |
I did the same on brakes on my 69, all the pcs came from a 75 C10. I had to drill the holes in the frame for the brake hoses tho. after that, I used the master,lines , & prop valve from the 75(mounted in the same spot Scoti has his). I also used the '75 12bolt,along with the brakes on it. Mine is manual disc, so I couldnt say what mods need to be done for the later booster. best of luck,crazyL
http://community.webshots.com/user/hotrodhorn |
09-06-2005, 07:26 PM | #5 | |
09-06-2005, 10:25 PM | #6 |
68 in progress
ok thanks that is what I was looking for. Now I can finally get my lines this weekend.
