Old 09-12-2005, 10:18 AM   #1
EricOlsen
Foot starter
Hi Y'all.
I'm a new member. I have a '58 3/4 ton with a foot starter. About a month ago it spun one of the rod bearings and I'm thinking of replacing the 235 6 cyl with a small block V-8. However, I really like the foot starter and was wondering if anyone knows if I can retain the foot starter while swapping the motor?
Thanks,
Eric
EricOlsen is offline   Reply With Quote
Old 09-13-2005, 01:06 AM   #2
OrangeMach
OrangeMach's Avatar
Holy crap! A 3/4 ton with a 235? That would never fly in todays world .
sorry for the hijack.
OrangeMach is offline   Reply With Quote
Old 09-13-2005, 08:05 AM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Welcome to the fourms EricOlsen!
The foot starter should just be an electric switch (at least my ol 46 was this way). Therefore its only a matter of getting the wire to the starter/cyl.
I would think it would be easier to KEEP it as a foot start.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 09-13-2005, 10:02 AM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
in my '59 3/4 ton the foot starter was basically a pedal with a mechanical linkage that pushed a button on the starter. you could find a starter button and mount it where the starter pedal was. it would be wired between the ignition and the starter.
1-ton of fun is offline   Reply With Quote
Old 09-13-2005, 12:47 PM   #5
rico_bob
"Treasure the Ride"
rico_bob's Avatar
The starters are not interchangable that I know of... so the switch would have to be wired without the mechanical device that touches down on the starter to run the solenoid. my 2-cents worth rico_bob
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 09-13-2005, 08:08 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have seen the conversion you want , but for thr life of me I can't remember where it was. They do make one and if I find it again I'll post where. it was a conversion for a modern GM starter to be able to continue using the pedal and on off switch setup.
dwcsr is offline   Reply With Quote
