An American Soldier
![]() Join Date: Feb 2005
The Never Ending Ram Horn Saga
Okay, I still do not have my ram horn manifolds on my truck. Not so urgent since the exhaust pipes have not arrived yet.
here's my issue. I thought I would use all new hardware. that being the case, I only brought two bolts for the manifolds back with me from the salvage yard. One short one that goes on th e ends...need 8, and one long one for the center..need four. Unfortunately, Kragens nor a local part store had the bolts. I went to a hardware store and looked at Grade 8 bolts, but the ones closest to each were like a 1/4" longer...I'm not sure that will work. Anybody know where to get the right bolts....I know..go back to the salvage yard and look on the ground where I left them...lol
Dan dan.brue@us.army.mil |
'65 GMC Project
ARP maybe?
Beauty is in the eye of the beer holder 1965 GMC project 1999 GMC Safari (daily driver) 2005 Scion XB (Wifey's car) |
An American Soldier
That's what I thought. I just perused their on-line catalog. It seems all their exhaust stuff is studs or bolts for headers.
'65 GMC Project
What size are they? If they're an oddball size the only other solution I can think of is to cut new grade 8 bolts down to the size your looking for. LMC doesn't even carry them.
http://www.stage8.com/auto.htm has locking bolt kits for Rams Horn manifolds. Part # 8920. Plated with locking retainers that keep them from ever loosening due to bolt movement. My last purchase was $57.82 shipped.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
![]() Join Date: Aug 2003
Bolts
Try a hardware store and you might have to use a washer also. Some hardware stores can also order the oddball lengths.
I used a couple of extra washers PLUS used a tap to go up into the hole and "clean-up" the extra threads that are up high in the hole. It worked fine in all but a couple of holes. With those, I cut the bolt and carefully shaped the end with a file to get them to start real nice. Its somewhat of a pain in the a$$ but it'll save you some bucks over buying a custom fit set.
![]() Join Date: Sep 2005
i guess u don't have a place like i do here in winston-salem nc i got a store called salem fasters thye have every bolt nut screw u can think of if i can find their number i'l post it i don't know if the ship or not.
![]() Join Date: Apr 2000
Part # 1256623 from Classic Industrise. But I would go back to the yard and get the old ones. Here is the link
http://www.parts123.com/PartFrame.as...sic_Industries
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters Last edited by 1-PU70; 09-30-2005 at 03:15 PM. |
Look in the Yellow Pages for a Fastener business. If they don't have them you need to go back to the wrecking yard.
What sizes do you need. I can get graded bolts at a place called Blue Collar and I like going there. If I have the correct bolts I will send them to you. EDIT: I just remembered that BB intake manifold bolts also work.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. Last edited by tomatocity; 09-30-2005 at 01:19 PM. |
LS1 Lover
Do you just need soem stock header bolts ? I just pulled my 327 out and it has the stock ramhorn's on it I can pull the bolts off for you if you'd like pm me if you want to work something out.
![]() Join Date: Mar 2001
If you need/want stock manifold bolts...go to your local GM dealer and get 'em.
The correct exhaust bolts will have a circle in the center. Other than that, might try a Tractor Supply Company and get Allen Head/Hex Head GR8 bolts. I ended up purchasing the 1/8" thick washers from ARP.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
#13 |
An American Soldier
Hey Guys..went back to the wrecking yard today...got 'em.
