Old 10-25-2005, 01:25 AM   #1
72orangepumpkin
Father of a Chevy Boy!
72orangepumpkin's Avatar
Harmonic Balancer Big Block Question
I'm trying to pull this part off a big block 72 motor and have never done anything like this before. When looking at the front there are 4 bolts... one down the center which apparently bolts to the shaft and three smaller bolts in a triangle. When I pulled the three smaller bolts out the front pulley came off. I then pulled the center bolt out and expected the rest to slide off the shaft, but the balancer and pullies are still steadfast. I'm trying to get it off without damaging the the pullies or the timing cover behind it!
Any ideas? Does this look familar to anyone? The orange ring behind the pullies is the harmonic balancer right?? Thanks, Chris
72 Chevy 4x4
Restoration in progress!
72orangepumpkin is offline   Reply With Quote
Old 10-25-2005, 01:35 AM   #2
71shortfleet
Re: Harmonic Balancer Big Block Question
Ok, if you removed the three outside bolts but left the center bolt on, the pulleys are just stuck due to time and road grime. Smack 'em with a hammer and they will break free. Or some that I've seen are 1 piece and can't be taken apart.
The center bolt holds your harmonic balancer on the crank. Remove that bolt. Then use a harmonic balancer puller WITH INSTRUCTIONS to remove the harmonic balancer.
71shortfleet is offline   Reply With Quote
Old 10-25-2005, 07:47 AM   #3
Ed ke6bnl
Your almost there did mine on my 454 1980 you need to rent/ buy a harmonic balancer remover a good one. and it is used to install the balancer with a roller washer. the problem I had with the 80 and my not be with the older motor is the three small bolts were metric so check the three small thread for a match when it is time to screw them in to pull from. Are Autozone rents the tool for free and it was a great quality tool. have since bought the tool kit will do power steering pumps also. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 10-25-2005, 09:45 AM   #4
truckdude239
truckdude239's Avatar
i used an steering whell puller
truckdude239 is offline   Reply With Quote
Old 10-25-2005, 11:48 AM   #5
72orangepumpkin
Thanks for the replies, Today I'm going to try to find a harmonic balancer puller at one of my local auto parts stores. Members of the board save the day again!
72 Chevy 4x4
Old 10-26-2005, 01:46 AM   #6
72orangepumpkin
Today I borrowed a HB puller from my neighbor and it worked like a champ. What a sweet tool!!! Thanks for all the advise!
72 Chevy 4x4
Old 10-26-2005, 07:38 AM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
now ask your neighbor for a installer when you go back together dont use a 2x4 and hammer only reason is you can damage the bearings from smacking the crankshaft
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
