Old 11-05-2005, 11:05 PM   #1
obsesive23
Who me?
obsesive23's Avatar
Question Help, Three on the tree problems......
My truck just started acting up on friday. It won't stay in third gear. I drove it home in second gear mostly. Is the tranny toast or is something loose? Any help would be greatly appreciated.
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline   Reply With Quote
Old 11-05-2005, 11:45 PM   #2
tiltbed69
Re: Help, Three on the tree problems......
sounds like the old saginal tranny`s 3rd gear syncro is toast.not to hard a fix if you are mechanicaly inclined......or just find a saginal 4 speed ...they are found in monzas,skyhawks,sunbirds,compact mid 70`s GM rear wheel drive,Sid
tiltbed69 is offline   Reply With Quote
Old 11-06-2005, 12:24 AM   #3
jimfulco
Might try adjusting the 2-3 shift rod (hooks to the front-most lever on the trans). But first, check the bushings in the shift linkage. If they're shot, it might not push it all the way into gear, which can cause it to pop out.
Edited to correct front/rear error.
jimfulco is offline   Reply With Quote
Old 11-06-2005, 11:48 AM   #4
73737373
Where can ya buy bushings? Am going to put the 3 speed back in my truck and saved all the pieces, except for the bushings. PM me. Jim
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 11-06-2005, 12:37 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
GM dealer will have the bushings.
Jimfulco, the 2-3 lever is the front one on the trans, the rear is the 1-R lever.
Old 11-06-2005, 02:29 PM   #6
davidh
davidh's Avatar
I got some bushings at Oreily's. They were in the red HELP section and were for a ford but were basically the same. My tranny was hanging up and sticking too. Afterwards has been basically no problems.
davidh is offline   Reply With Quote
Old 11-08-2005, 02:15 AM   #7
jimfulco
What was I thinking???
Old 11-08-2005, 06:14 PM   #8
rage'nrat638
rage'nrat638's Avatar
Red face Re: Help, Three on the tree problems......
this may sound stupid...but..if your cab to the frame rubber bushings are shot....the cab sagg's and bind's the shift linkages....ware's out the shift rubber grommits..etc..
rage'nrat638 is offline   Reply With Quote
