Old 11-10-2005, 08:46 PM   #1
dutchboy1
Steering box
Ok gurus out there. Is there a difference between a 2wheel drive and a four wheel drive steering box on a 72 blazer? This is the ongoing brainstorming of whether to convert my 4x4 to a 4x2 or not. Trying to work through the steering problems I might encounter.
dutchboy1 is offline   Reply With Quote
Old 11-10-2005, 10:16 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: Steering box
Yes they are different.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-12-2005, 04:41 PM   #3
earl87gta
earl87gta's Avatar
Re: Steering box
Yap I think they turn in opposite directions. When you go to cross over steering you have to change to a 2 wheel drive box.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-12-2005, 07:05 PM   #4
dutchboy1
Re: Steering box
So then does a 2wd steering box mount in the same position? I have a 76 2wd pickup frame with the front and rear suspension, tranny crossmember, tie rods and such but no steering box. I can get one at the local junkyard without any problem.
Old 11-12-2005, 07:14 PM   #5
earl87gta
earl87gta's Avatar
Re: Steering box
Yap it will bolt right in no mods needed.
Earl
Old 11-13-2005, 06:52 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Steering box
Double check the column shaft for excess play before you but it,
seals can be replaced / rebuilt, I would be concerned about play.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-20-2005, 08:26 AM   #7
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Re: Steering box
Use a steering box off of a 80-87, they are less turns lock to lock. Nice.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 11-20-2005, 10:21 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Steering box
A2wd box rotated side to side while the 4wd box rotates front to back..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-20-2005, 01:33 PM   #9
1976K5CHALET
1976K5CHALET's Avatar
Re: Steering box
The only differences between the two gear boxes is the output shaft. When converting to crossover steering you can swap in the 2wd sector shaft and away you go. I have all my boxes built by Benchworks steering in scottsdale arizona. 1-480-946-3992.
A few other points to ponder.....mid 76 the ratio's of the boxes changed....and somewhere around 78-79...the lines changed from a
compression fitting to an o-ring (teflon) seal.
The reason i recommend benchworks is i lived in phx for 12 years and drove
by the atsco rebuild plant everyday...benchworks is a small shop that hand
builds each unit....i like quality of quantity. They rebuilt my 4x box...added the 2wd sector shaft and ported the box for a hydraulic ram for $225. Cheaper than AGR...and better quality.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
