Old 11-18-2005, 11:41 AM   #1
76bonanza
76bonanza's Avatar
intake fittings
I have found a vaccum fitting for my intake with the ports I need but have a few questions. First is the vaccum hole 3/8?(edlebrock air gap dont think it matters tho)
Second looks like the PO used some kind of goop silicon or something when I remove the old fitting and clean the hole what should I use to seal it (I was thinking plumbers tape or something.) And about how tight all the way in till very snug or just so long as it is in a fair bit?
Thanks for your help I know this may seem easy just never done it before.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-18-2005, 07:50 PM   #2
76bonanza
76bonanza's Avatar
Re: intake fittings
No one seems like an easy question
1968 c10
lowered 3" 4"
Old 11-18-2005, 08:54 PM   #3
FormerMember
Re: intake fittings
Not sure on the first one, you could use any that provided enough vacuum.
I use teflon (plumber's tape) anytime I am working with vacuum or compressed air.
FormerMember is offline   Reply With Quote
Old 11-18-2005, 09:00 PM   #4
76bonanza
76bonanza's Avatar
Re: intake fittings
I guess on the first one what I mean is, is the threaded hole in the intake 3/8inch?
1968 c10
lowered 3" 4"
Old 11-18-2005, 09:07 PM   #5
FormerMember
Re: intake fittings
no idea, without seeing it.
Old 11-18-2005, 09:14 PM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: intake fittings
either coolant port im guessing coolant port maybe where a coolant temp. gauge goes or where the heater core hose goes ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-18-2005, 10:24 PM   #7
Sweet72
Sweet72's Avatar
Re: intake fittings
Careful not to over tighten the brass vacuum fitting in the aluminum intake as there's a good possibility of cracking the alum. casting. Just snug, maybe 20-25 in. lbs. and 3-4 threads left showing on the fitting. Nice choice in the Air Gap intake. My guess is 3/8 pipe thread. Oh, definitely use teflon tape.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
