Old 12-07-2005, 01:50 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
BB casting number - where are they??
About BB casting numbers:
1.) where are they
2.) how do you read them to tell if the block is numbers matching to the VIN of the truck it is in?
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
72 longhorn BB is offline   Reply With Quote
Old 12-07-2005, 02:56 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: BB casting number - where are they??
block castings are on the back of the block behind the distributer. same as a smallblock
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 12-07-2005, 03:04 PM   #3
clay68c10
clay68c10's Avatar
There is also a stamped # at the front passenger deck surface, just in front of the cyl head. That's the one with the model and hp rating codes.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-07-2005, 04:33 PM   #4
Dean
Dean's Avatar
Date code is on the side of the block I believe.
Dean is offline   Reply With Quote
Old 12-07-2005, 09:07 PM   #5
franko72
Franko72
franko72's Avatar
clay6810 has right answer. I found info for my 402 BB on the front passenger deck ledge on the block just in front of the cylinder head
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 12-07-2005, 09:40 PM   #6
Purs
Got Big Block?
Purs's Avatar
Here is a good diagram and explanation:
http://www.mortec.com/location.htm
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
