BEST way to swap cabs by yourself?
Need to swap another truck cab.
Done this before by myself, but thought I'd ask, is there a best way to do this by yourself? Thanks. ric |
67 is sold
Re: BEST way to swap cabs by yourself?
Without a chainfall, bobcat or forklift handy , a Cherry picker, 2x6 board through the windows and a 2" cargo strap
Joe - Formerly 67c10step ------------------------------- 1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD gr8lakes - My ebay auctions Click here to order forum apparel :: Click here to become a subscribing member Last edited by Joe67; 12-12-2005 at 12:54 PM. |
steroids help, i am planning to buy some beer and make some phone calls to some buddies that is the best and safest i have found even though they are all drunk.
square body trucks an addiction or an investment either way they consume all my extra time and money |
I have a Case skidsteer and a boom pole. I built a sling using 2" straps that went through the windows in the doors. After I lifted the cab and placed it on the frame I noticed the tops of the door frames under the staps were slightly dimpled from the weight. Doors still seemed to work right. The next attempt I removed the doors and ran the straps from the sling under the cab. I lifted the cab onto 4x4's across the frame, then jacked the cab down onto the frame by hand.
I don't do this too often thought somebody might have a better way to do this than me. Thanks. ric |
*Proud Member*
![]() i did mine with a cherry picker - worked out pretty well... the thing is just very akward and front heavy... once you get the chasis rolled out, and the cab lowered down, its not too bad... |
Gentleman Jim Driver
I used camper jacks, worked like a charm.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Real Men Wear Orange
It makes sense spreading the weight out as best as possible would be best...I'm not sure if it's okay to put a strap through the back window as long as theres no actual window. Same with windshield.
I've used camper jacks on a '80 Buick LeSabre body before. ElGracho is right.
Works Great. |
#9 | |
![]() a good shot of 300mg/ml IM of test prop/300mg tren acetate IM 3 hours before the time of lifting the cab ![]() do that, and you can lift the truck and slide off the cab... thats how we do it here ![]()
1987 350 TBI lowered 5/7 |
Parts and more parts
I have a two post pedestal lift, but a friend of mine took a 4X4 post and mounted it on TOP of his engine hoist and after he took the doors off of the truck he inserted the lift into the cab and raised the 4 X 4 up to the door frames and lifted the cab up. He had the post where it would swivel at the mounting point and he kept the cab level as he lifted it.
