Old 12-20-2005, 11:25 PM   #1
ozzyracing
Thumbs up Muncie
I currently have a 65 GMC with a 454 and a turbo 350. What will I need to install a Muncie M22 besides the transmission, money, time, and a new drive shaft?
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 12-21-2005, 01:23 AM   #2
1974gmc
In Progress
1974gmc's Avatar
Re: Muncie
manual tranny pedal assembly
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 12-21-2005, 12:33 PM   #3
ozzyracing
Re: Muncie
Is there a kit I can buy?
65 SWB 454 350T
Old 12-21-2005, 05:56 PM   #4
1974gmc
In Progress
1974gmc's Avatar
Re: Muncie
you will most likely have to go to a junkyard
Old 12-22-2005, 12:19 PM   #5
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: Muncie
a good clutch to last behind the big block, is that the rock crusher trans? it should be about the same length as the 350 ,watch the spline count on input and output shafts might be different on a rock crusher.is the motor drilled for pilot bushing/bearing? flywheel bellhousing starter maybe different.It's worth the work for play factor, gets tiresome on a daily driver.
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
