Old 12-23-2005, 02:02 AM   #1
Kantosensei
Body Mount Replacement Questions and Exhaust systems
I need to replace my body mounts on my 72 Blazer. Can anyone give me any pointers or pictures of the mounts being changed. I do have access to a lift and various floor jacks. Also, I am going to need to replace a couple of the bolts that are bent. Does anyone know if new nuts and bolts come with the Prothane body mount sets, or if there is a different brand that has nuts and bolts? If not, does anyone know what size the bolts are and where I can order the bolts? I live in Japan and can't run down to the hardware store and pick up SAE bolts. I also need a complete exhaust system. Does anyone know of a place that can make one so that it can go through the U.S. mail. I have access to welding equipment, so installing will not be a problem--I just need to get it here.--Thanks everyone this is a great board.
Kantosensei is offline   Reply With Quote
Old 12-23-2005, 03:28 AM   #2
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
Re: Body Mount Replacement Questions and Exhaust systems
I was checking out the same stuff for body mounts. Check out [URL="http://www.gmcpauls.com/67-72_parts.htm"]
I found a body mount kit w/the hardware.
ClassicJimmy is offline   Reply With Quote
Old 12-23-2005, 03:48 AM   #3
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-23-2005, 03:48 AM   #4
krue
Designated A-hole!
krue's Avatar
Fixed the link for you.
www.daveramsey.com
Old 12-23-2005, 07:18 AM   #5
vtblazer
vtblazer's Avatar
As fas as changing out the body mounts, I've heard/found that doing one side at a time is the way to go.
An american truck project in Japan, that's cool.
Welcome to the board, enjoy the ride.
vtblazer is offline   Reply With Quote
Old 12-23-2005, 07:27 AM   #6
krue
Designated A-hole!
krue's Avatar
Not trying to be nosy, but are you stationed in Japan by any chance?
www.daveramsey.com
Old 12-23-2005, 10:02 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Like vt said one side at a time but watch the fuel filler hoses and steering shaft.. Welcome to the board from southern oregon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-23-2005, 10:33 AM   #8
VinceY
Just need a couple more parts.
VinceY's Avatar
Replacing the body mounts was time consuming.
I did mine about a month ago and there are 12 bolts you will need. I thought mine would be good since I was able to loosen the nuts so I got a bushing kit without the bolts. Turned out I replaced all the bolts anyway. My advice for someone not living close to a bolt supply house is to order the kit with bolts. 8 of the 12 bolts were 3/8" carriage bolts. From what I remember 2 were 10" long, 2 were 4-1/2" long and the rest were 5-1/2" long. The bolts by the rad and in front of the front seats are larger and may not be easy for you to find. I jacked off my rocker boxes, bed floor in the back, and support under the rad in the front.
Check out the magizine article I posted in FAQ about this as it may be helpful.
Good luck
1947 Studebaker M5 project to match the camping trailer.
1950 Chev 4x4 Pickup
1958 Shasta Airflyte Travel trailer (fresh restoration)
1971 C/10 Pickup(Frame off Restoration)
1972 K5 Blazer CST (Daily Driver & My Company Truck)
1976 Honda CB750 Bobber
1988 Jaguar XJ12
VinceY is offline   Reply With Quote
Old 12-23-2005, 10:50 AM   #9
wrathchild
LIKE 'EM BIG AND TOPLESS
wrathchild's Avatar
Don't mean to hijack the thread ..just a quick question..when installing a bodylift,do I use with new body mounts or in place of the body mounts?
Merry x-mas everyone.....wrath
wrathchild is offline   Reply With Quote
Old 12-23-2005, 11:11 AM   #10
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Pretty straight forward process, just time consuming. My prothane kit from Summit didn't come with bolts, I got those at home depot. All the existing bolts were tack welded to the bed/floorpan so I had to grind those off for removal. Be sure to grease new polyurathane body mounts so squeeking doesn't become an issue. Try to have your jacking point as close to a mount as possible and don't jack any further than needed to remove/replace. I spread the jacking load out by using pieces of 2 X 4". Loosen all the body mounts on each side but just remove/replace one at a time and leave loose. After all mounts have been replaced then tighten. I used lock washers and tightened until bottom piece started to deflect. The two toughest ones for me were the two in the very back by the tailgate. The two at the radiator support requires at least the loosening of the radiator to move it out of the way or in my case I took it out completely. Have fun!
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 12-23-2005, 07:50 PM   #11
Medicanman71
Medicanman71's Avatar
did you get the blazer in japan?
Medicanman71 is offline   Reply With Quote
Old 12-24-2005, 02:06 AM   #12
Kantosensei
No, I didn't get it in Japan. I have owned the truck for about twelve years. My wife is a Dept of Defense elementary school teacher (2nd Grade). We were allowed to ship one vehicle on our orders. Sometimes I wonder about my sanity, or insanity, but we shipped the Blazer over here after it had sit in my parents backyard for six years. I'll try to post some pictures soon as it is a very clean, dependable truck. Thanks for all the advice.
Old 12-24-2005, 06:21 PM   #13
kyle4381
Can anyone post a diagram of how the body mounts go on....
kyle4381 is offline   Reply With Quote
Old 12-25-2005, 12:56 AM   #14
71jimmy
71jimmy's Avatar
I used the pics in the LMC catalog. Was better than my factory GMC manual. If you don't have an LMC catalog I would order one right now. They have very good illustrations and of course all the parts you'll need.
PS. We do however want to support our vendors that support this board first.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 12-25-2005, 09:51 AM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
and
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
