12-30-2005, 01:21 PM | #1 |
Senoir Member
WTB: Front gauge tin for vac/tach
I need a front gauge tin to complete my gauge rebuild.....I need one with the cutout for a vac gauge & tach. Well at least the vac cutout, I can cut the tach hole if needed. I can use paypal. Thanks, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
01-01-2006, 12:47 AM | #2 |
Senoir Member
Re: WTB: Front gauge tin for vac/tach
ttt
01-06-2006, 06:58 AM | #3 |
Senoir Member
ttt
01-06-2006, 08:29 AM | #4 |
Greg, I have cut a vac hole using a dremel tool and the end result comes out pretty good. You might want to give it a try if you can't find a correct original. You could also use one that was for air pressure as they had the hole you need. Good luck
01-10-2006, 04:13 AM | #5 |
Senoir Member
I cut mine using a dremel tool, and it lets in more light around it than I like. I would like to find one with the factory rolled edges on all four bottom holes. Greg
01-14-2006, 01:04 AM | #6 |
Senoir Member
ttt
01-14-2006, 08:29 AM | #7 | |||
Union Electrician
Greg,
I have one that I would part with for $25 plus shipping, but it is need of some work. I have already had it sandblasted and reprimed, but it is pitted in a few spots and will require some putty work to cover the pits. If you are interested in it I will get some pics of later today. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-15-2006, 06:54 PM | #8 |
Senoir Member
Send a pic or 2. May be interested. Greg
01-16-2006, 07:11 AM | #9 | |||
Union Electrician
Greg, I was really bussy this weekend and I will get a pic sent out to you later this evening or tomorrow. Randy
01-25-2006, 06:57 PM | #10 |
Senoir Member
Still looking, several people are not responding.
