Old 01-02-2006, 01:17 PM   #1
67chevemall
67chevemall's Avatar
Hook up the Gen. Light?
Howdy!
I want to hook up the Gen. Light to work beside the
Battery gauge.(they both have benifits I find)
Looking at the wiring blueprint the Gen light works
from a 16/20 gauge BRN wire from the volt Reg.
to the bulb on the cluster?
Can I just hook a bulb up with the + going to the
brn on the Volt Reg. and the - grounded??
Cheers and Thanks!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-02-2006, 01:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Hook up the Gen. Light?
You'll need a positive wire on both ends of the bulb, but honestly I can't remember exactly how it goes.
Old 01-02-2006, 03:24 PM   #3
67chevemall
On the printed cirsut it is + brown and - in grounded.
Something in the volt reg must send + when the Alt stops????
Old 01-02-2006, 05:24 PM   #4
BubbaGreen
to make it effective...you need:
[IGN +12V] --> [bulb] --> [alt]
If the alternator fails, it grounds itself turning on the light.
You need the 12V from an ignition source or you wont be able to turn off your engine with the key as the alternator will always be "excited"
This set up is for a new style 3-wire alternator.
check out www.madelectrical.com for better info and diagrams.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 01-03-2006, 05:14 PM   #5
67chevemall
I have the 3 wire alt.
Not sure where to run the wires??
Old 01-04-2006, 02:02 PM   #6
67chevemall
t
t
t
Old 01-04-2006, 02:20 PM   #7
68speedalert
Semi-Senior Member
68speedalert's Avatar
I assume you mean the internal regulator GM style.
If you don't have a 2 wire connector for the regulator you can buy one at NAPA. The larger red wire goes straight to the stud that the battery feed wire goes to. the smaller white wire goes to the bulb. The bulb will need 12V KO on one side, the other side goes to the white wire of the reg. With KOEO, the reg is grounded and the gen light will illuminate. KOER, the white wire is not grounded (as long as the alt. is working) and the gen light is off.
I'll bet the origional system worked the same. If you have a wiring schematic and trace it down, you can tap off the OEM wiring at the old regulator.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 01-04-2006, 02:53 PM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
a pic
sneakysnake is offline   Reply With Quote
Old 01-04-2006, 05:22 PM   #9
68speedalert
Semi-Senior Member
VERY nice!!!!!
Old 01-07-2006, 02:16 PM   #10
67chevemall
so the switch in the dia. would be the volt reg.?
Old 01-07-2006, 05:39 PM   #11
jhow66
jhow66's Avatar
No. Ing. switch.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-08-2006, 07:07 AM   #12
67chevemall
Roger. Thanks guys
you rock.....
