Old 07-15-2002, 05:24 PM   #1
silverader
67 pu
i have a 67 chevy pu it is standard i bought a motor for it and it doesn't have a place for the linkage to screw into the block is there a piece i can buy or something
silverader is offline   Reply With Quote
Old 07-15-2002, 07:36 PM   #2
jones
more details please.
floor or column shift?
6 or 8 cylinder?
I assume you're talking about the clutch linkage?
please advise.
BTW- welcome to the forum. I'm new here myself, and I've found it to have a wealth of information & helpful members.
also remember to take advantage of the great search feature.
J
69 C15
86 K20
jones is offline   Reply With Quote
Old 07-15-2002, 07:54 PM   #3
Randy70C-10
Randy70C-10's Avatar
Yeah, welcome to the board. Your profile doesn't say where you're from. One of us might be your next-door neighbor.
Randy70C-10 is offline   Reply With Quote
Old 07-15-2002, 08:35 PM   #4
Super Chevy
Super Chevy's Avatar
welcome from ohio, i can help you when you get alittle more detailed,i assume your talking about the clutch pivet ball, does the new motor not have a spot for it to screw into,mabe you when from a 6cyl to an 8 cylender and now it doesnt match,i know there has got to be another vehical's pivet ball that would work for you if thats the case, Ill check back on this in alittle bit,
S-C
Super Chevy is offline   Reply With Quote
Old 07-15-2002, 09:18 PM   #5
bigjimzlll
bigjimzlll's Avatar
some of the newer blocks dont have the pivot ball hole drilled or tapped...there is a boss for it though..you can drill and tap if the motors still out of the truck
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
