Old 02-01-2006, 07:25 PM   #1
see ten
WTB this ad
see ten's Avatar
New exhaust w/6" drop pics
I have seen requests for pictures and info for this several times so I thought I would put up a couple pictures. The exhaust is 2.25" aluminumized tubing. I used the ECE trailing arm crossmember (thought I took a pic of the pipe running through it but apparently not). The pipe goes over the trans crossmember and through the trailing arm crossmember. I also had a balance tube installed. I asked about a X pipe but he just didn't think he could make it happen and remain above the height of the framerails. Here are a couple shots from the side just to show that nothing is below the framerails.
Here's the balance tube.
I had him stay outside of the rails after the axle in case I ever want to go back and add a rear fuel tank.
The driver's side was tight! We had to take the bolt out of the track bar and turn it around (face the head towards the front of the truck) in order to make room for the pipe.
The passenger side wasn't near as bad.
And of course the tips!
see ten is offline   Reply With Quote
Old 02-01-2006, 07:49 PM   #2
bkwagonss
Junior Member
bkwagonss's Avatar
Re: New exhaust w/6" drop pics
Wow, I like that. I didn't think you could have a 6" drop without cutting the frame out for the axle, let alone squezzing in the exhaust through there. Cool!
1971 Short Stepside,(sold)
2011 Caprice PPV
1950 Chevy Fleetline
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=302759
bkwagonss is offline   Reply With Quote
Old 02-01-2006, 08:12 PM   #3
1969owner
1969owner's Avatar
sweet, i like that
1969owner is offline   Reply With Quote
Old 02-01-2006, 08:14 PM   #4
FormerMember
Any contact with the suspension cycling? Looks like there might be.
Looks good, I hope I can get similiar work done!
FormerMember is offline   Reply With Quote
Old 02-01-2006, 08:20 PM   #5
see ten
WTB this ad
see ten's Avatar
No everything is kosher under there. The axle will hit the frame before it gets to the exhaust. The pipe was "massaged" somewhat next to the track bar for clearance.
Old 02-01-2006, 08:25 PM   #6
68jimmy
68jimmy's Avatar
Looks Great! Are you using headers and if so what brand and p/n?
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-01-2006, 08:40 PM   #7
see ten
WTB this ad
see ten's Avatar
It still has the stock manifolds.
Old 02-01-2006, 08:47 PM   #8
john@thepier
john@thepier's Avatar
see ten- what headers are you using? or stock exhaust manifolds. Would you strongly recomend an ece trailing-arm cross member for a 4/6 drop THANKS. JOHN
john@thepier is offline   Reply With Quote
Old 02-01-2006, 08:58 PM   #9
see ten
WTB this ad
see ten's Avatar
Stock manifolds my friend. ECE recomends the Xmember with anything more than 5" drop. I have seen many people on this board running big drops without it. If you run the ECE Xmember you will have to run a one piece driveshaft.
Old 02-01-2006, 09:20 PM   #10
70rs/ss
70rs/ss's Avatar
Some guys go outside the frame just before the rear hump in the frame and then run the pipe up and over the axle in the wheel tub. It gives great clearance and less severe bends in the pipe, yours looks nice, not baggin' on you just adding another option at there.
70rs/ss is offline   Reply With Quote
Old 02-01-2006, 09:20 PM   #11
1969burb
thanks for taking the time to get pictures, I do appreciate it! good tip on the one piece driveshaft, I didn't realize that. Since I just had my two piece balanced with all new u joints and the carrier bearing replaced I guess i'll be staying with the stock trailing arm crossmember for a while. oh well, thanks again. Steve
1969burb is offline   Reply With Quote
Old 02-01-2006, 09:27 PM   #12
NitroMike
Active Member
NitroMike's Avatar
Great install. Very clean. I'm more and more impressed with ECE part all the time.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 02-01-2006, 10:26 PM   #13
Rollie396
someday it will be done!
Rollie396's Avatar
Looks great see ten!
I notice you didn't c-notch the frame and I don't see any bumpstops.
Just wondering if you've had any probs with bottoming out?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 02-01-2006, 11:28 PM   #14
see ten
WTB this ad
see ten's Avatar
Thanks for the compliment. No there is not a notch and yes I removed the bumpstops. ECE claimed I would have 3" between the frame and the axle tube with this drop. It seems to me that I am closer to 2.5" of clearance. I don't know if my spray-in bedliner adds enough weight for the .5" of difference or not. I have not had any problems with it bottoming out while driving. A friend and I stood on the tailgate and bounced on it to try to see if it would hit. Well after about the third bounce it did. I think if I had enough weight in the back while driving it would hit under the right(wrong) conditions. I may end up installing a C-notch later so I can run a bumpstop or a compression bumpstop. I don't know if I would be better off installing a rear airbag setup to be able to haul loads or take my chances with a notch.
Old 02-01-2006, 11:54 PM   #15
Brad
Out of the carpool lane.
Brad's Avatar
That's awesome and thanks for posting pics. I nominate this for the FAQ section!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 02-02-2006, 12:13 AM   #16
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Fantastic. That is some smooth work. I'd bag it myself.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-02-2006, 11:12 AM   #17
Yukon Jack
Post Whore
Yukon Jack's Avatar
Clean install.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-02-2006, 11:35 AM   #18
gregfull
gregfull's Avatar
Looks great see ten! Crawl up under there and get me a pic of that crossmember. I'd like to see that part of it, I'm debating on putting that crossmember on my burb. Thanks for the pics.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 02-02-2006, 12:47 PM   #19
JIMS1972STEPSIDE
Junior Member
JIMS1972STEPSIDE's Avatar
Hi, I have a 72 C-10 that I am dropping 5 inches and would like a pic of your truck to see what it looks like, thanks. Jim
JIMS1972STEPSIDE is offline   Reply With Quote
Old 02-02-2006, 12:58 PM   #20
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
I like it. Looks like it took some time to figure out.
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 02-02-2006, 05:09 PM   #21
see ten
WTB this ad
see ten's Avatar
Here are a couple pictures of the truck for those who asked. I will try to get my buddy to bring his camera by tonight so I can get a picture of the ECE crossmember. The man who ran the tubing for me has about 30+ years of experience. He has actually stopped doing this kind of work due to health reasons. I called him to see if he could refer me to someone and he told me he had access to a shop to do jobs for his "old customers". If you didn't notice there is just one piece of tubing from the mufflers to the tips(nothing pieced together). He came off the manifolds with 2" pipe and when he got it parallel to the frame he went up to 2.25". He took his time on this job and was happy with how it turned out. It cost me all of $220 which I feel was a bargain. (These photos were made before I had the exhaust ran which is why you don't see the tips.)
Old 02-02-2006, 06:35 PM   #22
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looks good ASA
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-02-2006, 09:28 PM   #23
see ten
WTB this ad
see ten's Avatar
Dude! I went out there and laid down on the carport and stuck my arm under the truck for these pictures. I know they are kinda poor quality but I didn't want to drag out the jack in the rain.
Old 02-02-2006, 11:11 PM   #24
RODSBYT
RODSBYT's Avatar
Nice Ride!
I made a 2 1/2" system out the rear with ECE 6" drop.
I had to go under the trans crossmember, I kept it tight it only shows about
half the pipe under the frame from the side.
I made the Whole system using flowmaster universal tail pipe kits, and H pipe.
Flowmaster 50 series deltaflow stainless. check it out.
This is the first time posting pictures.....
RODSBYT is offline   Reply With Quote
Old 02-02-2006, 11:25 PM   #25
Rollie396
Rollie396's Avatar
Wow how thick is the plate on that Xmember?It looks real beefy (5/16-3/8) in those pics!
'80 LWB 2wd beater
my pics
