Old 02-19-2006, 10:00 PM   #1
4x4Poet
JB Conversions' New LoMax NP205 with 3:1 Low Range
In case you want the best NP205 transfer case available:
JB Conversions LoMax 205
Low range is 3 to 1 in a new NP205 style case with stouter gears! Super low range with no driveshaft changes needed. 32-spline versions are in stock and shipping but 10-spline input gears are in production. Figure 8 vs. round bolt pattern issues are also addressed. We all know that an NP205 is tough, but look at the size of those LoMax gears in comparison to stock NP205 gears! I'm computer illiterate, so would someone please post a comparison of the gear sizes. Or any pic you please. TIA.
Start dreaming and saving.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-20-2006, 12:26 AM   #2
1967k30
1967k30's Avatar
Re: JB Conversions' New LoMax NP205 with 3:1 Low Range
They sound cool,but I'm not sure if I can justify them .Looks like I'll run a 203/205 doubler ,or at least that's the current plan.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 02-20-2006, 12:31 AM   #3
4x4Poet
Originally Posted by 1967k30
They sound cool,but I'm not sure if I can justify them ...
Yeah, as with most great auto upgrades, the price kills. Still, that gear set says, "Go ahead. Stick me behind a CTD."
Old 02-20-2006, 01:41 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
The size of the gears is why you can't use the stock case.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-22-2006, 01:02 AM   #5
MrBinAz
MrBinAz's Avatar
-----the fleet-----
'72 K20 Chevy Suburban
'72 Datsun 510 (vintage racer)
'89 Honda Civic Si HB
'89 Honda Civic Dx HB
'08 Honda Element EX-P
'78 Honda Express (50cc. pit-ped)
pix here
MrBinAz is offline   Reply With Quote
Old 02-22-2006, 07:08 AM   #6
4x4Poet
Thanks, MrBinAz.
Drool, droool, drooooool....
Old 02-22-2006, 11:05 AM   #7
1967k30
1967k30's Avatar
My brother could sure test them in his CTD powered 67' K20 . It'll probably get a 203/205 behind it though.
Old 02-22-2006, 11:20 AM   #8
Chris_T
Why not both? A 205/205 gives 1:1, 2:1 and 4:1 (2:1 x 2:1). With that gearset in the 205 a doubler gives you 1:1, 2:1, 3:1 and 6:1 .. after all, it's not MY money
Chris_T is offline   Reply With Quote
Old 02-22-2006, 07:42 PM   #9
1969 GMC
1969 GMC's Avatar
I'm pretty sure you can get a 3:1 kit for the 203 range box from Wagoner Machine Shop for less money. The 3:1 205 is pretty bling, but...expensive.
That's what I would do if I was in the market for a doubler...but I'm not.
I offroaded just fine with a SM465 and Rockwell T221 (well, til it exploded) and didn't ever want to go lower. Unless I move to Colorado or Arizona, and have rocks to crawl on, lol.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-22-2006, 10:08 PM   #10
1967k30
1967k30's Avatar
You are correct WMS does have a 3:1 for the 203.Just imagine the possibilities. 3:1 203 and 3:1 205.That would be cool.WMS also offers a 203/203/205 setup. Which if all were setup with 3:1's it would be insane. Just a though.
Old 02-23-2006, 11:36 AM   #11
I`m too poor.The best I can do is a NV4500/NP241 and 4.56 axles.Which I have laying around,just need to start building that one.Well,first I have to swap a 208 into my`90 Blazer so I can rob the r/h 241.
Old 02-23-2006, 07:51 PM   #12
1969 GMC
1969 GMC's Avatar
Why? Just save some time and leave the 241 under the Blazer and just use the 208 behind the 4500. The difference in low range (to me) wouldn't be enough to justify a swap.
1969 GMC K2500
1996 Honda Accord
Old 03-01-2006, 11:35 AM   #13
Chris_T
Good point.
Kind of interesting to think about the difference between stacking a 2:1 and 3:1 gearset in either order.
For instance: Does a 3:1 rangebox put more stress on a stock 205? Would you be better with a 2:1 rangebox and a stronger 3:1 gearset in the 205? or if you'd rather not twin-stick your 205, would you like 2:1 or 3:1 2wd low from the rangebox?
All pretty academic to me since I moved and decided to restore my '72, but interesting to think about nonetheless ....
Old 03-14-2006, 01:10 PM   #14
454_72_4X4
454_72_4X4's Avatar
Good point.
I agree with the interesting part. Alot of things to think about when you start thinking about it...
I guess I need to go watch the crawlers someday. I very, very seldom use low range in my stock 205 let alone go lower yet!
My theory is "build a bigger engine"! Hahaha
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-16-2006, 03:31 AM   #15
4x4Poet
Besides having greater strength for handling the binding that comes from full lockers front and rear, the beauty of the LoMax NP205 gear set is the crawl ratio. With an SM465:
1st 6.32 x 3:1 xfer x 4.11 R&P = 77.9 final crawl ratio.
78 to 1 makes ample gearing "room" for over 35" tires.
Compare with stock crawl ratio:
6.32 x 1.96 x 4.11 = 50.1
Less weight, too. Expect less driveshaft breakage & u-joint wear than with doublers since a rear driveshaft behind a LoMax alone is longer and has less severe operating angles than driveshafts behind doublers.
Anyway, no one's going to talk me out of getting one.
Old 03-16-2006, 11:21 AM   #16
smokekiki
Mike
smokekiki's Avatar
Anyone call for a price on one?
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 03-16-2006, 11:30 AM   #17
454_72_4X4
454_72_4X4's Avatar
Now that I've read the whole article about it, it does seem like an excellent product.
I like the dual, (round and figure 8), mounting positions. And the big bearing 32 spline input is nice since 205's with that input arrangement are getting hard to come by.
The 3:1 gearset has it place I guess. For you crawler guys it'd be great, (or at least a big improvement over the stock 1.96:1).
I think they should've left the PTO plate on there too though.
Now for the big question, Price?
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 03-16-2006, 02:48 PM   #18
1967k30
1967k30's Avatar
They're $1300 . It's too bad they are so high.
Old 03-18-2006, 07:19 AM   #19
4x4Poet
Actually, that's reasonable for what they are. Stronger and lower than stock ratio NP205 gear sets with a new case that fits both round and figure 8 pattern mounting.
Ok, the LoMax is very expensive. I wish they weren't so high, also. Maybe they'll come down a little if volume sales start.
Edit: Hehe. Volume sales @ $1300 a pop! I crack myself up.
