Old 04-20-2006, 02:36 PM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Dash Lights Don't Work
I just drove my truck back from the body shop yesterday after having the cab replaced. I rewired the whole truck after I got it put back together. All the lights work (headlights, sidemarks, back-up, blinkers), but the dash lights. They worked before I took everything apart. Any ideas? Thanks.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 04-20-2006, 02:43 PM   #2
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
Re: Dash Lights Don't Work
Sounds like you have a bad ground contact somewhere.
I had a similar situation that I couldn't figure it out. Later on I cleaned all the contacts on my grounding straps and the lights came back on...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 04-20-2006, 02:44 PM   #3
Putter
More Cowbell....
Putter's Avatar
You don't have the dimmer portion of the headlight switch turned all the way off, do you?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-20-2006, 02:49 PM   #4
4tiresngas
An American Soldier
4tiresngas's Avatar
Putter, I did try that...not it. Catseye, I tried me messing with the ground right behind the dash besel. I think that might be the problem, because it is primered right now. It may not be making good contact...I'll keep messing with it.
Dan
Old 04-20-2006, 03:49 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If your inst panel wasn't grounded, your turn signal indiacors and fuel guage would be acting stupid too.
Take a good look for a pinched wire, maybe upon installing the steering column.
Old 04-21-2006, 04:59 PM   #6
madisonguy
madisonguy's Avatar
Is your headlight switch new or at least "lightly used"? I've had the potentiometers stop working altogether on older dash light dimmers before.
'70 LWB C/20 Custom
'95 Maxima SE
madisonguy is offline   Reply With Quote
Old 04-21-2006, 05:12 PM   #7
thecatseye66
'68 C-20 396 CST CC
Originally Posted by madisonguy
I've had the potentiometers stop working...
The what? How do you pronounce that?
Old 04-21-2006, 06:26 PM   #8
Longhorn Man
Alternant word; Rheostat.
Old 04-21-2006, 08:32 PM   #9
byrd
Union Electrician
byrd's Avatar
po-tent-chi-ometer close I think....
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-23-2006, 02:54 PM   #10
CheySuper8
G.M.uses the instrument lights to indicate that the stop lights are not working. Check your fuses for the tail lights.
CheySuper8 is offline   Reply With Quote
Old 04-23-2006, 03:14 PM   #11
Longhorn Man
...All the lights work (headlights, sidemarks, back-up, blinkers), but the dash lights...
He already did.
Old 04-23-2006, 04:48 PM   #12
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Dan, did you take the horseshoe connector for the steering column apart or something? There's a gray wire that feeds the dash harness there, and that is the power for your dash lights. I had a bad connection on my horseshoe one time and it killed the dash lights. Also, the heater lights tie in right there. Are they working? Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-23-2006, 08:36 PM   #13
70 shorty
Where's my beer?
70 shorty's Avatar
When my dash lights didn't work it was the switch itself that was bad. As yours does, everything else worked including the turn signal lights on the dash, the high beam indicator, just not the instrumentation lighting. All the outside lights worked right also.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 04-23-2006, 11:06 PM   #14
4tiresngas
An American Soldier
4tiresngas's Avatar
Thanks guys. I have not had time to look into it anymore this weekend. I'll let you know once I figure it out (and I will) exactly what it turns out to be.
Dan
