Old 04-25-2006, 08:57 PM   #1
farmtruckIII
71 GMC 454/TH400
farmtruckIII's Avatar
Big Block Swaps simplified
Hello all, I have been gone for a while but I did manage to find time to get the 454 shoe horned into the farm truck. After talking with some folks I decided to just do it my way. I sat the 454 on the stock 350 mounts, but it sat a bit too far forward. So then I got to looking at this issues, jacked the motor up and swapped the frame mounts side to side. Slid the mounts towards the front of the slot and drilled the holes for the bottom bolts. It made for tight clearance with my headers but it all fits! I was thinking of making a swap book what do y'all think?
"The bigger you are the harder you fall, the farther you walk the longer you crawl."
farmtruckIII is offline   Reply With Quote
Old 04-25-2006, 10:50 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Big Block Swaps simplified
What are you going to run for exhaust manifolds or headers? That's usually the main trouble with using small block stands.
Old 04-27-2006, 05:10 PM   #3
farmtruckIII
71 GMC 454/TH400
I clearanced the frame stad a tad bit and had to slightly dimple the header tube a wee bit. It all fits great! But however I am unsure if the BB headers are going to work with the drop componets I bought.
Old 04-27-2006, 09:02 PM   #4
junkyardjohn
junkyardjohn's Avatar
I'VE PUT SEVERAL BIG BLOCKS IN THESE TRUCKS, & THEY SEEM TO BE MADE FOR THEM (NO SURPRISE....THEY WERE). I HAVE ALWAYS USED THE CORRECT BIG BLOCK MOUNTS & HAVE NEVER HAD TO TRIM OR NOTCH OR DIMPLE ANYTHING. I GUESS YOU COULD SAY THEY FIT BETTER THAN GREAT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-27-2006, 09:16 PM   #5
TP from Cntl PA
TP from Cntl PA's Avatar
That is how they had the 454 in my K-20............Only problem was they cut some of the steel away on the plates where the motor mounts bolt to.........When we took the engine out, I wasn't too supprised when I seen that side was all cracked up from lack of structural strength. Luckly I have some extras to replace it.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 04-27-2006, 09:35 PM   #6
J Y Dog
Amazin' ain't it get the correct parts and no extra effort is required.( ya Caps lock is 0N)
JYD
J Y Dog is offline   Reply With Quote
Old 04-27-2006, 09:58 PM   #7
big blue 72
JYJ likes the CAPS.
big blue 72 is offline   Reply With Quote
Old 04-28-2006, 07:09 AM   #8
farmtruckIII
71 GMC 454/TH400
When working with limited funds and resources you do what you have to. I would have used big block stands if I could have found them. The clearance was miniscule not enough to hinder the performance of the mount, or effect exhaust flow in the header tube. I do know enough not to go hacking on a motor mount. This was a poor mans BB swap.
