frame differences and repairs
does anyone know the difference between a 1974 shortbed fleetside frame and a 1986 chevy suburban frame. i need to figure out the fastest and most efficient way to get my frame welded up. the reason i ask about these two vehicles is because i have one of each. thanks!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL!
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: frame differences and repairs
The Burb is longer and different. You cant swap them.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#3 | |
ureckmefixit2@cox.net
As long as the frame is the same C-chanel size you could frunt clip it but you better plate the frame thats if your frame is bent if you just want the bolt on parts it should all bolt in
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
From the front cab mount forward they are the same. They do make repair kits for these if it is broken at the steering box.
| Bookmarks |
