05-18-2006, 11:25 PM | #1 |
Replacing Oil Pan Gasket
Can I change my oil pan gasket with-out lifting the engine?
(1972 GMC, 2wd pick-up) Has anyone done this? I need to fix a minor leak. |
05-18-2006, 11:29 PM | #2 |
Re: Replacing Oil Pan Gasket
I did it, so I assume you can too. I was a little tricky to manipulate the pan past the oil pump pick up, but it can be done.
67 SWB |
05-18-2006, 11:39 PM | #3 |
I need to put a new oil pump in the 350, I hoped it wasn't gonna be too hard to get the pan off.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
05-19-2006, 12:24 AM | #4 |
I've done this without removing the engine. I removed the bolts from the mounts, jacked up the engine, re-installed the bolts into the mounts and set the engine back down on the bolts. This left me enough room to get the pan off.
Its a pain doing it in the truck though. If you can get a 1 piece gasket....much easier to install, is reusable, and almost surely won't leak. |
