![]() Join Date: Sep 2005
no fire no start
okay got a timing light this morning and timed my truck its sweet spot seemed to be 9 dregees btdc run good no pinging or nothing let it sit ilding it cut off now i have no fire from the coil replaced the coil and condenser still no fire got points and going to get a set of wires to make sure that the coil wire isn't bad any other things i need to look at and get it running again
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: no fire no start
make sure ya still have power TO the dist.
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
With the key on you should have about nine volts to the + side of the coil and while the starter is turning you should have 12 volts. The - side of the coil is connected to the points and condenser and ground when the points are closed and when they open the coil fires. You can run a jumper to the + side of the coil and see if it cranks the engine but don't leave it on or it will burn up the coil.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 06-18-2006 at 12:41 AM. |
check the resistor. and if it is good make sure you are not running an internally resisted coil!
check your points, could be adjusted too far out and not be closed enough to get fire. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
