Old 08-06-2002, 06:20 PM   #1
Slick71
Slick71's Avatar
Front driveshaft removal?
How do I get this thing out?? I took off the front bolts were it connects to the axle. What do I need to do to remove it from the transfer case end?? Are there clips or do I just pry it off?
It's a 71 4X4 with a 4 speed, if that matters.
THANKS in advance.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 08-06-2002, 07:09 PM   #2
ckhd
ckhd's Avatar
I don't know if it changed between '69 and '71, but on my '69 with a Timken t-case, there are bolts. It's not a U bolt, but a curvy piece of metal with two bolts on each side.
I haven't had to crawl up under the 'burb yet, so I'm not sure how the 205 t-cases are.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 08-06-2002, 07:53 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
I believe that the 205 has a flange on the t-case end. There are 4 bolts that mates the DS flange to the T-case flange.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-06-2002, 07:59 PM   #4
Blue_71
Bloo
Blue_71's Avatar
my 71 (SM465/NP205) has 4 bolts that hodl the driveshaft to the t-case, easiest way i found was to take out the floor hump and go down from that angle, there harder then heck to reach from the bottem IMO
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 08-07-2002, 07:55 AM   #5
Blazer1970
Blazer1970's Avatar
Yes the crossmember makes it very hard to get to those bolts from the bottom. It is possible to do it from the bottom, but it will take a long time because of limited wrench access.
Blazer1970 is offline   Reply With Quote
Old 08-07-2002, 09:56 AM   #6
'72 Cheyenne Super
Grab a 1/2" open end wrench (or was it a 7/16" at that end? I can't remember. Been too long), pack a small lunch, and bring a pillow, 'cuz you'll be under there a while removing the bolts that hold that end of the shaft to the T-case!
'72 Cheyenne Super 4x4, 468ci, 700R4, Import Stomper.
A couple pics at http://www.picturetrail.com/gallery/view?p=6&uid=529895&
'72 Cheyenne Super is offline   Reply With Quote
