Window installation/rope size?
I found the FAQ's on window installation (front or rear) for our trucks but there is not much information about the size of rope/cord that people use to put them in. Does anyone have any recommendations?
Thank you in advance.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
![]() Join Date: May 2005
Re: Window installation/rope size?
The glass shop I went to used a cord about the same size as a lawn mower start cord.
Hope this helps. Pete |
70 Chevy 3/4t
I used a string about the size you use for making a line, say for setting fence posts.
Find a job you love and you'll never have to work a day in your life. 1998 Yamaha V-Star 650 1970 Chevy 3/4t, I6 (rebuilt), 4 speed Kokomo,IN |
The entire point of the string is to manipulate the rubber around the channel. You won't want something too big that it doesn't easily move, and you don't want something so small that it rips or tears the rubber. I used string for fence posts like boilrman. It worked well on the front window, but tore the gasket on the back window. Perhaps I got too rough with it..?? Good luck, it's not the easiest of projects. Having someone help you is key also.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
#5 | |
![]() Thanks to all for your feedback!
Try a weedeater line. It is a plastic material and does not grab the rubber like rope or nylon does, slides real well when you lube the gasket with windex, dish soap or whatever. I have tried them all from twine to rope and have had the best performance with no grabbing or tearing with weedeater line.
Mike |
weedeater line is an awesome idea.
#8 | |
Larry if it takes another set of hands to help....let me know and I'm there!
#10 | |
Did ya get into the window moving biz??? LOL!!!
#12 | |
![]() I'm gonna try the weedeater line as suggested....sounds like it will work good since it will slide easier. ![]()
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" Last edited by Lemield; 07-21-2006 at 11:37 AM. |
#13 |
Well...I got it installed. It was tough. I decided to use some sash cord and it worked OK. Was going to use the weedeater line but only had the stuff with the sharp edges....I never would have gotten the window in without the my wife's help...she is a good helper!!!
#14 |
Good deal Larry!
#15 |
We used venetian blind cord and it worked well.
On a side note, does the rear slider window use the same seal as stock glass? I will be painting mine soon and will need new rubber.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#16 | |
