Old 08-04-2006, 12:26 AM   #1
GRAYGHOST
GRAYGHOST's Avatar
electric fans question
I want to put electric fans on my truck. My question is, how do you wire the fans using a thermo switch? Thanks for the help.
GRAYGHOST is offline   Reply With Quote
Old 08-04-2006, 09:11 AM   #2
jamon8
jamon8's Avatar
Re: electric fans question
make sure that u use a relay!!!!
when you buy an adjustable thermo switch it will come with directions
again- make sure you use a relay
jamon8 is offline   Reply With Quote
Old 08-04-2006, 09:31 AM   #3
67chevemall
67chevemall's Avatar
I'd just use a toggle switch. keep it simple and you always know if it is working or not.
And don't forget that relay.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-04-2006, 08:09 PM   #4
67gmcss
A severe novice here, but I was wondering Why the relay was so important?
67gmcss is offline   Reply With Quote
Old 08-04-2006, 09:21 PM   #5
Sweet72
Sweet72's Avatar
The fans draw alot of current and a relay is capable of handling this current, the thermal switch is not. Use the thermal switch to control the windings of the relay and the relay contacts to switch the fan/fans on and off. A toggle switch to override the thermal switch would be a good idea. Monitor your water temp closely with the elec fans. I've heard horror stories of guys burning up their expensive engines when/if the fans stop working due to a bad thermal switch, relay etc...
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-05-2006, 05:03 PM   #6
Sweet72
Sweet72's Avatar
I found this, hope it helps you understand how the circuit should be wired. http://www.aaroncake.net/rx-7/efaninstall.htm
Old 08-05-2006, 05:28 PM   #7
gangforward
Hootis is as Hootis does...
gangforward's Avatar
I got the kit from Wes for my truck (383 stroker, headers, etc) it is well thought out, complete, and works awesome!
Strong endorsement - Wes's kit is da' bomb!
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 08-05-2006, 11:03 PM   #8
76bonanza
76bonanza's Avatar
2nd on the kit from wes. No relay either switch is controled with grounds, power wired right to battery
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 08-05-2006, 11:52 PM   #9
chevy50
New Member
I found if you wire the fan to a toggle switch instead of a relay,if you go to shut your motor down,it will keep runnin until the fan quits turnin.Strange,eh?
chevy50 is offline   Reply With Quote
Old 08-06-2006, 07:52 AM   #10
aitch
aitch's Avatar
Thanks for posting that link. It should be a must read for anyone considering installing an electric fan set-up.
It pretty much debunks the horsepower gains advertised by Black Max and others.
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
