Old 08-11-2006, 10:05 AM   #1
badchev69
Active Member
badchev69's Avatar
lift, crossover, new engine build (two week deadline)
Not sure why my projects always end up this way but i commited to take my 72k5 to a carshow in 2 weeks the weekend of the 26th and as it sits today the suspension is all apart, the cross over steer conversion is far from together oh and did i mention my motor is in as many peices as possible in my garage?
Saturday (12th) im driving down to redding to pickup the rest of the lift from greg(Monsterk5) so lift will be done this weekend. Running 4"flip + 8"skyjacker springs with 1"+ shackle in the rear for 13". Up front is getting 10" skyjackers with 1" zero rate for a total of 11". Should be large.
Crossover, i still need the steering arms and drag link.
Motor, well thats going to the machine shop this weekend to get punched .30 over and i hope to have it running by next weekend.
Then all that is left is to touch up and paint my engine compartment while it is still out. Finding the time to do all this while working 50hrs a week... who knows???
Well if anyone is in oregon the show is at the Sublimity Harvest Fest grounds, usually attracts about 300 or so cars mosty hot rods and there is a burn out contest, which i got 1st in last year with my c10. maybe see you there...
Progress pics will be posted here later this weekend.
Wish me luck and some ambition!
1969 C10 SWB /350 vortech/th400
1968 SWB build (in progress)
1969 SWB build (my son's future project)
1968 camaro yellow/white stripes (wife's car)
2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's
1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst.
350/350 (sold it )
badchev69 is offline   Reply With Quote
Old 08-11-2006, 12:26 PM   #2
Burt4x4
Burt4x4's Avatar
Re: lift, crossover, new engine build (two week deadline)
Get-R-Done
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 08-12-2006, 06:51 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good luck
Owner/Op: "TN Classic Transport Carriers"
Daily Driver: "HerNameIsRio" 68 GMC SWB
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Toy Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-12-2006, 09:41 AM   #4
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Good luck!! You can do it!! Lots of pics please.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 08-12-2006, 12:17 PM   #5
RunTMCfan
RunTMCfan's Avatar
May the force be with you. Click on this link. It may provide you with some motivation. It has audio.
http://www.iwo.com/heroes.htm
Rob
"RunTMCfan"
RunTMCfan is offline   Reply With Quote
Old 08-12-2006, 01:01 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Keep us posted thats a lot of work to do in a short time frame..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-12-2006, 07:55 PM   #7
badchev69
Active Member
badchev69's Avatar
Well i just got back from cali, left at 4 this mourning and got back at 4:45pm. 730miles later im going outside to see what i can get done... ill get you some pics later tonight.!
350/350 (sold it )
Old 08-13-2006, 04:20 AM   #8
krue
Designated A-hole!
krue's Avatar
Good luck with it!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-13-2006, 01:44 PM   #9
badchev69
Active Member
badchev69's Avatar
Well phase 1, the suspension, is pretty much done. Here are some pics of the progress. The front ended up lower than i was calculating ecpecially since there is no motor in it yet.... Ill have to figure that one out. The back is missing the gas tank so that will help a little plus the top will bring her down more but it will still have the rake to it.
shakle flip from ORD
the new 8" skyjacker springs
350/350 (sold it )
Old 08-13-2006, 01:45 PM   #10
badchev69
Active Member
badchev69's Avatar
and some more....
350/350 (sold it )
Old 08-13-2006, 02:19 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Looks like your gonna need more lift in the front...
MEMBER #6377
Project "7DEUCE"
Old 08-13-2006, 03:02 PM   #12
badchev69
Active Member
badchev69's Avatar
mmm ya i know the front is suckin right now. The motor is gonna suck it down even more so im thinkin maybe zero rates and throw the shorter stock shackles in the rear again to try and even it out.
Any other suggestions?
350/350 (sold it )
Old 08-13-2006, 03:22 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
How about this..
MEMBER #6377
Project "7DEUCE"
Old 08-14-2006, 12:54 AM   #14
badchev69
Active Member
badchev69's Avatar
haha ya there is a solution! if only money wasnt a problem....
Found the handy tape measure and got some specs..
ground to top of rear fender well= 53"
ground to top of front fender well= 51"
ground to bottom of frame is 33 1/2"
so it looks like im short at least 3" or so in the front to bring it up and
compensate for the lack of motor. I do have 1" zero rates i can try plus a front memeber to drop the front spring mounts about 2" should be in order.
350/350 (sold it )
Old 08-25-2006, 03:13 PM   #15
badchev69
Active Member
badchev69's Avatar
WOW where did the time go? Well sorry i didnt update... ever but i finished the k5 last night at about 3:30 in the AM. I drove it to work today and everything checks out minus 2 things... vacume leak and the damn rear brake line is leaking.... the collar is cracked
I should be able to pick up a new one after work, snap some last minute pics and post them for ya. Tomorrow is the show, Ill be taking my 69 C10 and the 72 K5. Ill be sure to bring the camara in case i see something worth shooting.
350/350 (sold it )
Old 08-25-2006, 03:26 PM   #16
krue
Designated A-hole!
krue's Avatar
www.daveramsey.com
Old 08-25-2006, 05:51 PM   #17
Chevyman63
Chevyman63's Avatar
Very impressive!
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 08-25-2006, 09:21 PM   #18
Yukon Jack
Yukon Jack's Avatar
Congrats on getting it done!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-26-2006, 01:18 PM   #19
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Now that is a MONSTER!!! Where is the car show? Great looking lift by the way.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-26-2006, 05:45 PM   #20
MNorby
MNorby's Avatar
Looks sweet and i love the color combo and the tire/wheel selections. They go together really nice!
MNorby is offline   Reply With Quote
Old 08-28-2006, 02:33 AM   #21
badchev69
Active Member
badchev69's Avatar
Well here are some pics from the show, The first one is me getting there first hah!
At a different show that same day in Salem OR.
350/350 (sold it )
Old 08-28-2006, 02:38 AM   #22
badchev69
Active Member
badchev69's Avatar
I just realized i didnt really take any more pics of my Blazer at the show, I guess i was too busy with the other cars there, Anyways i ended up with a 2nd place trophy for the 4wd class, I was beat by an 84 chevy 4wd dually converson with swampers. Not really my style at all but it definantly had alot of hard work into it, flat bed lots of stainless and fresh paint. Ill be up against him again this weekend, we shall see who is victorious again...
Well i have some other random car pics ill put up for ya from the weekend adventure!
350/350 (sold it )
Old 08-28-2006, 02:43 AM   #23
badchev69
Active Member
badchev69's Avatar
Here they are...
First the wifes car...
then my buddies K5
Then some 67-72 trucks
finnaly some randoms..
350/350 (sold it )
Old 08-28-2006, 02:46 AM   #24
badchev69
Active Member
badchev69's Avatar
And some more...
350/350 (sold it )
Old 08-28-2006, 05:59 AM   #25
Chevyman63
Chevyman63's Avatar
Awesome pics, thanks!
1972 4x4 Blazer
RIP
- CLR 10/11/09
