Junior Member
couple ?'s
How can you tell if you have a double wall top?
How heavy are the top's? |
![]() Join Date: Jul 2002
Re: couple ?'s
Double wall......bolts bottom up......single wall....top down. Double wall....like I have.....no idea on weight.......but I'd guess from lifting mine....about 200-ish.....Single wall weight....I have no experiance on that one.....
Patch |
I'm a poor spectator
Re: couple ?'s
I've got the double wall then I guess too. Is one more valuable than the other? My dad and I took mine off and it was pretty tough. Three people would make more sense.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: couple ?'s
I've heard that more people want the singles.....but I personally like my double.....Three people definately works better......The single wall tops also have curteousy lights on one side I think....
Patch |
The LuvShack Garage
Re: couple ?'s
Patch got most of it right, Yes a single has dome lights in it, the same
oval type like in a regular cab truck, the advantage to a Single wall is that IF you have rear cargo panels they will have to be removed with a double, where as in a Single wall since it bolts from the top down the panels do not need to be removed to get the top off, and if you have a 72 model it is possible that your bed rails are drilled for both, because they do NOT use the same mounting holes to bolt on except in the frt. on top of the windsheild, and in the back near the tailgate, cya later
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 09-02-2006 at 08:19 PM. |
| Bookmarks |
