Hey all!
Hi folks! I just recently found this forum, and I figured I should join since I owned a Blazer and all. My name is Kevin, and I live in the Phoenix, AZ area. I have a 1970 Chevy Blazer known as "The Banana" because of it's yellow paint job. I bought the truck about 2 years ago from the original owners, and I really haven't done much to it except for replacing the fuel filter, fuel lines, drum brakes, and master brake cylinder. I also switched the gas tank to a 35 gal. Along with "The Banana" have a 1986 GMC Sierra Classic 3/4 ton pickup that does most of the dirty work. I just stuck a new 350 engine in it, and the tranny is fairly new. I love the truck cause it's durable, and dependable, and it goes wherever I want it to go. Anyway, I'll probably be asking you guys a lot of questions as I want to start getting my Blazer project up and rolling! Thanks.
--Kevin
1970 Chevy Blazer, a.k.a. "The Banana" |
The LuvShack Garage
Re: Hey all!
From West TN
Owner/Op: "TN Classic Transport Carriers" Daily Driver: "HerNameIsRio" 68 GMC SWB The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Toy Hauler: "Feathers" 14 Aluma 8218T |
computer illiterate
Re: Hey all!
welcome to the board. what application is the gas tank from? got any pics of the install?
72 2wd blazer 72 swb 4x4 |
Re: Hey all!
Post some pics we all want to see..
Re: Hey all!
The gas tank was an aftermarket unit that the previous owners just hadn't installed yet. I'm not sure where it was purchased from. It was pretty easy to mount under the truck. It just took two bolts through each side of the chassis, and reattaching the sender cable and it was done. I attached a picture of how the tank is mounted.
The previous owner did some strange stuff to this truck. Stuff that I managed to overlook when I bought it. They had a lot of homemade solutions to problems or modifications that aren't super appealing. For instance, the truck has it's original hard top, but they cut into the top to install a sunroof. They didn't do such a good job installing the sunroof either, as it is crooked and there are globs of hardend sealent around the glass to keep it from leaking. So thanks to that I am in search of a new hard top. I don't care if it is a double or single wall top, I just want one that I can replace the old top with. I have a soft top, but they just don't look as good as the hard tops do. How difficult would it be to find a hard top to replace my old one? Anyway, I also attached another photo of the front of the truck. The front end is really nice and straight. The rear needs a little work, but nothing super bad. There are also a couple spots of rust below the doors from the truck being driven in Mayrland, where it was originally purchased. Eventually I'm going to replace the exhaust manifold on the truck with a set of headers that I bought from a friend. Along with that I'm going to replace the rest of the exhaust system and give it a new muffler and exhaust pipe since the old one is rusted through in some spots. The truck has a crate 350 with 45,000 miles on it which runs pretty well, but the choke isn't hooked up so it takes a few extra minutes to get it started. So that's pretty much the scoop on the old Banana. It needs a bunch of work, but I have it to where I can drive it regularly and still turn some heads out on the roads. --Kevin
![]() Join Date: Apr 2004
Re: Hey all!
your blazer should have a double wall top, if you install a single you will need to do some fab work. The bolt patten is different. Check your local craigslist.com for a top. I just found a half cab for mine on there.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Re: Hey all!
Welcome To The Boards! Nice Blazer!!
Brian Smith - "Born To Lose"1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
Gone Fishing
Re: Hey all!
Welcome to the board from Texas
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
The Blazer King
Re: Hey all!
Bananna colored are the best!!
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
It's ok to stare...
Re: Hey all!
Welcome to the board from northern California!!!
Designated A-hole!
Re: Hey all!
Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: Hey all!
From Oregon
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
#13 |
Can't wait to retire!!
Re: Hey all!
from Michigan.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#14 |
Re: Hey all!
Thanks for the warm welcome folks. I'm glad I found some other Blazer fanatics!
--Kevin
#15 |
PROJECT 7DEUCE
Re: Hey all!
Welcome ..
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#16 |
![]() Join Date: Feb 2000
Re: Hey all!
Welcome! Looks like a sweet K5. Get some more pics posted - we are picture crazy here!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
| Bookmarks |
