Old 10-05-2006, 10:28 AM   #1
Project SIKty-5
Project SIKty-5's Avatar
Question 64-66 Chop Top?
What's up everybody, new to this site....just wondering if anybody out there has a 64-66 with a chop? If so, how much of a chop and got any progress pics??
Project SIKty-5 is offline   Reply With Quote
Old 10-06-2006, 12:53 AM   #2
Eagar1
Re: 64-66 Chop Top?
I think you would have to section the roof to make up for the lost front to back dimension you cut out of it, at either the top or bottom, or you will end up laying the windshield back a quite a steep angle. You could probably section it right in front of the raised area in the back. Cut that first, leave the back intact. Then cut the front down to desired height, the move rear down to match, then close the gap opened up on the top, possibly from a donor roof, then do the same thing with the side doors, then have glass custom cut etc. I think that is how I would do it.
Eagar1 is offline   Reply With Quote
Old 10-06-2006, 12:56 AM   #3
Eagar1
Re: 64-66 Chop Top?
Oh and you may want to go with the big window in the back to save on metal work and increase visability.
Old 10-06-2006, 03:33 AM   #4
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: 64-66 Chop Top?
If you have a small window please keep it. (IMO) It will look better as a small window....
AesC10s is offline   Reply With Quote
Old 10-08-2006, 03:57 PM   #5
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: 64-66 Chop Top?
Ive got one in progress I had to quarter the roof and my donor roof clip
I took it down 4 inches , its all tacked but Ive moved onto other things for now
Ill try and remeber to take pics next time im at the shizzznop
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 10-08-2006, 07:14 PM   #6
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: 64-66 Chop Top?
Are you gonna finish it?
Old 10-08-2006, 09:39 PM   #7
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: 64-66 Chop Top?
Id like to think so
part of me wishes I had gone 6 to be extreme
its just not a priority right now
1964 Short box
1972 K10
Old 10-10-2006, 11:25 AM   #8
Project SIKty-5
Re: 64-66 Chop Top?
I was trying to find some progress pics of other's chop work. I've chopped mine and basically cut it into quarters, w/a donor roof to make up the difference from front to back. I believe I'll need a filler piece for the middle section. The chop ended up being about 2.25", I wanted to keep it kinda subtle. I got the back 2 sections tacked on, but I'm worried about joining them and keeping them aligned, because they don't quite touch. Any suggestions??
Old 10-10-2006, 09:03 PM   #9
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: 64-66 Chop Top?
I need more front to back and down the middle thats why I quyartered it I took a lil extra both ways off my donor clip!
post some pics if you can
to keep em alligned you can just tack on some srtaight peices of whatever bar or straight anything you have lying around while you weld em up
1964 Short box
1972 K10
Old 10-10-2006, 09:12 PM   #10
zenish
Re: 64-66 Chop Top?
what will you do about the windsheild?ive read that they are a ***** to cut and not break.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 10-10-2006, 09:18 PM   #11
Slammed66
Needs a Big Block
Slammed66's Avatar
Re: 64-66 Chop Top?
Brain with the BADPNL the 66 panel with the 6' chop has talked me thru it Ill ask him again or tell him to stop by and shed some light but he sand blasted his to cut it , he has the specifics I have em written down at the shop , but it took a long ass time like 8 hours of slowly working back and forth
1964 Short box
1972 K10
Old 10-11-2006, 12:46 AM   #12
Project SIKty-5
Re: 64-66 Chop Top?
Ya, I used the donor roof for the extra length front to back, but as for side to side, I couldn't use the rear roof pieces because it was a small window. So that forces me to use a filler piece.....the thing that sucks is the gap is only about 1/2", but I don't want to tweak the pillars in to make up the difference. It sure does look good w/a chop though.....who would've thought cutting would be so much fun!!
By the way, thanks for all the info and help guys....this place rocks
Old 09-07-2007, 12:34 PM   #13
satin64
satin64's Avatar
Re: 64-66 Chop Top?
any pics or updates on your guys chops?
satin64 is offline   Reply With Quote
Old 09-07-2007, 05:43 PM   #14
L0WRIDE
L0WRIDE's Avatar
Re: 64-66 Chop Top?
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 09-07-2007, 05:59 PM   #15
Todd_a
Re: 64-66 Chop Top?
Id like to think so
I like the 4" chop a little better than 6" on these trucks. But that is jsut my opinion.
Todd_a is offline   Reply With Quote
Old 09-07-2007, 08:48 PM   #16
truckn'
truckn''s Avatar
Re: 64-66 Chop Top?
truckn' is offline   Reply With Quote
Old 09-07-2007, 10:38 PM   #17
Swerve-Driver
Re: 64-66 Chop Top?
Has anyone ever used a WaterJet with abrasive to cut a windshield? It would be tough to get the cutting head to follow the curve on the windshield, but might work pretty well on the long flats.
Just a thought, was wondering if it had been considered.
S-D
Swerve-Driver is offline   Reply With Quote
Old 09-08-2007, 11:06 AM   #18
918733
Re: 64-66 Chop Top?
You supposed to be able to take out 3 inches without cutting the top into 4 pieces. According to IFcustoms.com And if you look at the pics of I think Lemondrop his truck is chopped and the roof does not look sectioned. But does anyone have any pics or links on chopping a 65? Thanks
918733 is offline   Reply With Quote
Old 09-08-2007, 01:07 PM   #19
satin64
satin64's Avatar
Re: 64-66 Chop Top?
yeah im interested too.......i need to replace my roof and i may as well chop it in the progress.
Old 09-08-2007, 09:40 PM   #20
laidout
Active Member
laidout's Avatar
Re: 64-66 Chop Top?
there was a 65 on ebay that would be perfect to see how to chop the top
you could see all the welds it was awsome
laidout is offline   Reply With Quote
Old 09-10-2007, 03:07 AM   #21
satin64
satin64's Avatar
Re: 64-66 Chop Top?
anyone got some links or pics or something?im looking for a new cab or at least roof section.i want to do a 3 or 4 inch chop.
Old 09-26-2007, 11:03 PM   #22
satin64
satin64's Avatar
Re: 64-66 Chop Top?
picking up my new roof tomorrow.some where i read that you dont need to quarter the roof if you stay 3" or less on the chop,is this so?is there a link to it?i did a search but didnt see it.any help would be appreciated
